Mugen MTX-3
Originally posted by rjl
asw, you must not run the tyres (english) untrued. The fronts will be too large and it will get worse. Out of the box, Zacs are usually 66mm front and 65mm rear.
I find that 35s are good on low grip so I assume that is the conditions you run.
I would set the ride height to 7.5mm both front and rear on 64mm diameter, then depending on the length of the heat I reduce the front tyre diameter by an amount that will finish the heat at slightly less than the rears.
What I'm trying to say is that the car will be a pig if your front tyres are larger than the rears and it puts too much strain on the drive train.
but are you sure about kawahara / zac's tyres diameter F/R is different ? Thx, I don't notice that until now. What about using smaller / higher pulley at front ? so I don't need to put extra attention with belt strain / drive train issue ?
asw7576,
Sorry, you'll find there is no escaping the need for correct tyre sizing.
You will need a tyre truer or to get friendly with someone who has one.
whats a good size to start off with? i dont want to true off to much s whats the minimum truing diameter?
"get friendly with someone who has one. "
Ha... ha.... ha.... nice one! actually there are nice people in race track who could lend me tyre truer, but I don't want to..... I just drive and go.
I true my tyres at rear 62mm front 60mm
If i want great handling right away i true rear 60mm front 59mm
Always works for me
Always works for me
All these guys are right. At some point you'll have to true down at least your front tires. You'll notice a HUGE difference
heres a tricky one. IŽd like a couple suggestions on how to obtain even wear on untrued foams using one way and stock belts. for instance. 35 front 40 rear, etc etc
here are the issues. I do not have access to a tire truer, prices of foam here are about 39 a set. I do have the kawahara conversion but puts too much stress on the front and side pulleys and the belt is low friction but with low life. and finally, I suppose that If I use front diff the wear will be even now right.? suggestions appreciated!
tire wear
Where do you live? You can get great tires at a low price here in the states. WWW.RCTexas.com This guy also carrys a low cost pretty descent tire truer,made by G.Q.
As far as the pullys, I have always used the stock ones.Do you run on a permanant track or a Car Parking lot?
tyre truing
hello guys...
i guess tyre truing etc is or part of a good technical advantages in racing , nevertheless for me i have not had the chance to do this...but still can have good outing/results in races that i've taken part.
what i am trying to say for amateurs like me its not that critical.....
after all this is a fun hobby
just my 2-3 cents
just my 2-3 cents
Always works for me
Always works for me
have you try to use smaller tires. 58 or 59 very well for me. i even used 56mm on qualifying.
ake mashite omedetou gozaimasu!
Re: tyre truing
Originally posted by rcabj
hello guys...
just my 2-3 cents
hello guys...
just my 2-3 cents
What is your setup ? stock blue springs with 600 weight oil ?
re: tyre truing
Hiya,
I never true my tires in my MTX 3 ( i do in 1/8th !!!)......Found that trued tires did not affected lap time that much...actually i was quicker with tires out of the box rather than with the recommended split. I normally uses one set front to three set rear ( tired kawahara conversion 16/19...rear still wear at the same rate....hence gone back to stock setup.....
There are some good drivers at my club, whom will always truing their tires. i am not exactly slow at my club, as when i race with some top drivers such as mark green, i would be second and about 0.5sec behind.
Can any other MTX 3 owners out there verified that truing tires had not made any different to their lap times, and some explanations why not ? Coz i don`t know why....whereas in 1/8th it`s very important !!!
