Mugen MTX-3
Old 10-03-2004, 09:22 PM
  #14131
rcabj's Avatar
Default Re: gear ratio?
Originally posted by gentleman81
i am running stock gearing in my mtx 3 which is 47/43 to 16/20 and i geuss these are 1.0 gears. i saw a guy at the track who had a bad a$$ motor but also had the 0.8 gears and it screamed!!
it seems as if my car goes though the gears a little slow for me, i race a technical track with at least one good long strecth, what are some suggestions for gearing. i asked the guy but of course i didnt remember it or right it down (in front of him )
i'm doin quite well right now with the current setup in the last two races...
if i were to get the 0.8 gears , will i be getting my lap time half a second faster per lap...??
if that is the case , it is worthed for sure gettin the 0.8 gears...
rcabj is offline
Old 10-04-2004, 06:48 AM
  #14132
Taylor-Racing's Avatar
Default Re: 16/19 conversion
Originally posted by xtreme888
Hi Guys,
I am running the 16/19 conversion with a metal 16 kawahara rear side pully and belt......the problem is that the 16 pully and belt are worn away very quick....belt replacement after about 4 meeting and pully about 8 meeting. Is there any plastic gear out there a can replace the metal pully with coz i noticed that the 19 plastic pully with very little wear !!! Hence was thinking if i replace the metal one the belt would last longer. Is there any other similar conversion that i can use to make the front tyres wear more quicker like the 16/19 conversion?
Sounds like the alloy pulley is wearing the teeth to sharp points which then damages the belt and it follows suit, and fails.
Just get the Mugen pulley set as sugested and use the 16T that's in there. You might try soaking the side belt in WD-40 over a couple of days. This helps soften it up and all should be good.
As a side note, we use the 3Racing 16T alloy pulley - 'cos it was available quickly and locally at the time. I'm not a big fan of 3Racing stuff but this pulley is holding up just fine. When it gets worn, we'll just swap to the Mugen plastic one.
Taylor-Racing is offline
Old 10-04-2004, 06:52 AM
  #14133
Default Re: Re: gear ratio?
Sorry, the 0.8M gears are fine but there's no half second in it.
Old 10-04-2004, 06:57 AM
  #14134
While on the subject of gears, does anyone know of a 19T first gear (0.8M)?
I believe Kawahara make one but thought there might be an easier alternative - maybe from another make of car.
Old 10-04-2004, 07:08 AM
  #14135
rcabj's Avatar
Default Re: Re: Re: gear ratio?
then , how about quarter of a second???
rcabj is offline
Old 10-04-2004, 07:26 AM
  #14136
Default Re: Re: Re: Re: gear ratio?
Don't think so . . . . maybe about 0.001 sec.
Worth having all the same.
Old 10-04-2004, 07:50 AM
  #14137
rcabj's Avatar
Default Re: Re: Re: Re: Re: gear ratio?
seriously ... for example same car, same setup, same driver only 100 of a second difference?
rcabj is offline
Old 10-04-2004, 07:58 AM
  #14138
Picard's Avatar
Tr is just playing games.
Dont listen to him, he is going into an overdue retirement
Picard is offline
  #14139
Need to sell
MTX3 Pro Spec Car Kit:
The car in the box with the kuwahara rear brace, racing dynamics receiver battery , brand new set of twister tires never touched the ground.
http://www.pbase.com/evanb/image/34532059
$375
Spare parts which are all good spares in the bags (gears, belts, thurst bearing, tires, etc.)
http://www.pbase.com/evanb/image/34532062
$75
Ofna Starter Box(again brand new with 2 300 viper packs):
http://www.pbase.com/evanb/image/34532055
$50
Mazda 6 Custom Painted Body(custom never mounted)
http://www.pbase.com/evanb/image/34532098
$75
Mugen X12 Engine & Mugen Pipe
$325
Paypal accepted, all these items donot include shipping
e420x is offline
Old 10-04-2004, 07:59 AM
  #14140
Default Re: Re: Re: Re: Re: Re: gear ratio?
OK, seriously then. The 0.8M gears are more efficient but I wouldn't be expecting to find anything difinative and measureable in lap times.
For instance, you'd have more chance of finding some time by experimenting with clutch set-up.
Old 10-04-2004, 08:15 AM
  #14141
rcabj,
Don't listen to Picard. The last time I saw him, he was up to his ankles in broken dogbones and shock shafts.
Old 10-04-2004, 08:18 AM
  #14142
rcabj's Avatar
Default Re: Re: Re: Re: Re: Re: Re: gear ratio?
TR...i'm just making simple assumptions from my last race where my best lap times r in the 0.5-1.0 second difference per lap with the top guys.
considering my motor is rather "old" and not having a suitable pipe , and also the 'gear' thing.... i imply that i could have improve
my time and lessen the difference of lap time from the top guys when i rectify the things i mention above...do u agree...
(..i also assume the top guys r havin perfect setup of everything compared to me...)
rcabj is offline
Old 10-04-2004, 08:24 AM
  #14143
Picard's Avatar
If you are a novice driver the best thing you can do is practice turning laps at the track and get your lines and braking points spot on...this will give you the best effect on lap times.
Once you are comfortable with the track start experimenting with the setup
Picard is offline
Old 10-04-2004, 08:33 AM
  #14144
Yep, Picard is right. There just isn't anything significant in the gears.
Spend money on tyres and time at the track - there is no escaping this.
I was saying to Picard yesterday that I counted some empty tyre boxes I'd been keeping for a while, just for fun. There were 86 boxes and that's not all of them.
Old 10-04-2004, 08:53 AM
  #14145
rcabj's Avatar
thanks for the tips guys....
rcabj is offline
