Mugen MTX-3
Originally posted by eddiethefish
Yes, Radio Controlled, but then it's us human to do the IMPROVISATION!
Thanks to DATA for this thought.
Originally posted by Ah10
You are asking a question that no one can answer!
If you had to put it this way then go back to stock setting and start from there
Originally posted by Varuth
Where can I find a stock setup?
Re: Re: Re: servos
Do most people using ABS?
ABS??? Never heard of it No need to cheat
I use the Futaba 9451 digital for steering, gives plenty of speed and torque. And a Futaba 3010, used to use the 3003, for throttle/break. Just a little bit faster than the 3003 but alot more torque for better braking.
So, the higher rebound stop, e.g. 6mm = less droop?
And 1mm rebound stop = more droop.?
correct.
part of the reason why less droop is used in the rear is because it gives you better braking stability.
less droop: more stable, better brake stability
more droop: more responsive, less stable
use more droop on rougher tracks, while smooth tracks use less
I'm currently using +2mm in front and +6 in rear on the Vision. I believe these are the stock settings for the Mugen as well
Re: FYI
Well, it's Friday. Wife's here with me, got nothing else to do, but behave.
Just for fun, guys... Take a look at the beauty of what hopups have to offer:
First Gear Adapter
Later, I might do some comparison between'em.
cheers,
boring fish
First Gear Adapter
cheers,
boring fish
Re: Re: FYI
Originally posted by B
I pick fivestars
I pick fivestars
Don't forget my JR R-1 has this Anti-lock Brake System (ABS), too!
Anti Lock Brake, I know for the fact that M8, 3PK, KO Mars and a few more radio has this feature.
Re: Re: Re: FYI
That's my pick too!
That's my pick too!
correct.
correct.
Fish
Fish: What chassis are you running ?
