Mugen MTX-3
#9406
Re: Re: Wanna konw about breaking
Originally posted by Manticore
i dont break !!
brake is for pit stop !
i dont break !!
#9407
AERODYNAMICS OF A BUMBLE BEE
I think it looks cool though
#9409
Originally posted by stefan
I have cut very small pieces (3 coils) from a ballpen spring, which is relatively soft and put it between my brakepads, works great.
Another brake mod that I think is working wonderfull is to bevel your brake cam where it is touches the brake pads.
Usually this area has a sharp angle, but if you round the edge off, your brake comes in more gradually and smoother.
#9410
can anyone tell me anything about shooter hop-ups for the mtx3? how does it compare with the craft and finish of the sato seiki or is it one and the same?
#9411
#9412
anyone tried a front fix shaft for mtx3 instead of the one way?
would it be mad to drive?
anyone remove the 1.5mm spacer behind?
#9413
I used the Associated 1/12 scale front softest springs (.018" - sorry don't have the part no. at hand) but had many problems with them, faced coil bind problems - springs were a little too long - when brake was applied and the springs were too stiff and separated with too much force the brake pads and the other edge rubbed with the disk brake (not too much but enough to wear unevenly the brake pads).
Happy Holidays All!
#9414
similar quality but it seems shooter has put more thought on its products.
#9415
Originally posted by EVOLUTION
Do they have a website dear?
#9416
#9417
Thanks.
#9418
this shooter roll bar is the best among the rest. the roll bar bolted on the upperdeck mount and take away the stress from the upper deck. fit both seden and Lola
#9419
here's the pic
#9420
Originally posted by eddiethefish
Hi those pro guys. I would like to know if we really use break for nitro on road cars. Some pro, like surikarn, said don't, some said yes. So what is the correct and fastest way to drive?
I think there is no way you can say that you will not brake at all. I guess it depends on the track and the driver. For me I do not brake much, usually at the end of the straight only. But i read somewhere in here before that if you set your brakes to make the car twitch a little on braking it will make the car turn in faster. I tried it and it really works! Its not easy to remember that you are doing the braking to twitch the car on purpose. Tire wear is not bad at all too.
