Mugen MTX-3
#8296
Ok another noob question....
Why is there such difference in speed between the intermediate and the expert class? Now, I'm not talking about driving skills. Just the pure speed/acceleration of the cars. All the engines are .12 roar legal none-turbo...
It it fuel? Tweaking of engine? Or allowing the engines to run extremely lean? What is it? What is competitive racing engine temperature?? Because I was amazed at the speed of them expert cars...I mean I could have a perferctly driven race and not even come close to any of them because my car is just slower.
G
G
#8297
fuel and tweaking of the engine. Good temps are like around 255.
#8298
When you say fuel you mean like what? 30%?? Tweaking in terms of tuning right ? Or actual physical tweaking of the engine itself??
G
G
#8299
Thanks Cartman, I'll have to try some red locktite this weekend. The blue I tried didn't work. If the red doesn't work, JB weld!
Originally posted by Cartman
i have seen this in the UK on various brands of housing
get RED lock tite clean all parts with motor spray, apply plenty of it to outside of bearing AND housing push them together and wipe excess immediately DO NOT clean with any spray as it will was away the lock tite.
this worked on mine
ignore the other posts and do it, i am a motor mechanic with 20 years experience! and if done correctly it will work!
this worked on mine
#8300
#8302
the difference in speed is these things.
Though the TRP runs good it is about on par with an MT, it is no match for the new novarossi's or serios.
2nd how long is your pipe and which one do you have, the pipe and its length makes a huge difference.
3rd many of the guys running the newer high rpm HP engines are gearing down because the newer engines turn up so hard. the lower gearing gives them tremendous punch and the engine makes up the top end.
4th many of the racers use 30% fuel and tune for 250 ranges on temp some are using 40%
5th there is alot of performance in the clutch of the car, an often overlooked part, clutch performance is important
all of this adds up to the difference you see.
#8303
ok tighten your servo saver two turns to stop the hubs flicking back!
#8304
Hey people.
I got a Question for all you MTX-3 people i just got the SUPER HARD CLUTCH SPRING and the LIGHT WEIGHT CENTRIFUGAL SHOE. and i have just fited it all on and the car and started it up when i first started it nomally and sounded nomall and then when i put it down and started to drive around It became very load and the engin was reving alot more than nomally at "ilde" just sitting there not moving it was very reving hard. And as soon as i put tapped the triger it ENGAUGED very quick and dorve around nommal.
My question is that is the engin meet to be revving this hard when at idle. Is that just becuase of the HARD SPRING.
THANKS any help will be great.
#8305
i guess the engine's idle is not related to the clutch maybe??
did you re-check the throttle linkage after putting the engine back onto the chassis?
#8306
Originally posted by EVOLUTION
Many good things being said about these engines,keep us posted Corse.
#8307
I took the bearing out, put some blue threadlock on it, put it back in, but it still backing out. I tried putting another bead of threadlock around the seam between the bearing and the housing, but that didn't work either.
This is my second housing to do this. I've also heard that several aftermarket 2nd gear housings have the same problem.
In addition to the Loctite, you could also score the housing with a new hobby knife. The scoring will produce raised edges which will in turn produce a tighter fit. This is the same concept as "Knurling" for those who know. Score at 12, 3, 6, and 9 o'clock and test fit.
#8308
Originally posted by Vinyard
Isn't that a Picco engine? pls enlighten
#8309
Surge,
You could also insert the bearing into the housing and "dimple" the surrounding housing with a center-punch or a scribe. The resulting deformed aluminum will hold the bearing in. Dimple at 12, 3, 6, and 9 o'clock. Take it easy with the hammer strikes though, don't want to deform the metal too much.
#8310
