Mugen MTX-3
#8206
Anybody have a set up for the 3 for a race lot that is big and smooth. Also is the set ups for the one-way and the front diff. the same, whats better for the medium sized tracks? Thanks
#8207
Fuel Tank Leaking
Does anyone have problem on their fuel tank leaking or it just me?
I've change 2 fuel tanks and both leak at almost the same spot at the rear mounting point (the one facing the engine), the line that join the pieces of the tank. I can't melt the thing with my solder since it is at the screw mounting position, so i did add some silicone glue, but still leak after some run.
Is there an update optional fuel tank out there by some other hopup company?
#8208
the leakage possibly caused by the round edge of the upper deck. simply file that point to make it flat for more clearance for the fuel tank.
#8209
Need to get a new fuel tank and try your method.
#8210
YES, Manti is right ............file the radio plate round the fuel tank. No more leaking fuel tank for me now!!
#8211
Re: Wonder no more of how the fish's been up to
Originally posted by eddiethefish
Hello guys,
Sorry that I've been off the thread for some time, got some health problem. Man, I surely missed some goodies while I was gone. Gotta catch up!
hope there won't be any one to claim about the copyright here.
best,
fish
Hello guys,
best,
fish
#8212
Re: Fuel Tank Leaking
#8213
Nizee - I had the same problem. I cleaned it up, applied a little shoegoo, and then worked it into the little crack with a warm ( not hot ) soldering iron.
I just plugged the soldering iron in long enough so it would barely melt plastic.
Plug the pressure line with a short piece of fuel tubing and a screw, and blow into the other line while the tank is in a bowl of water just to check for little leaks. ( hold the lib shut too, btw! ) If it leaks, you'll see bubbles.
#8214
Re: Re: Fuel Tank Leaking
Originally posted by ROBBIE C
Check your new tank for leaks before installation, if it leaks send it in I will send you a new tank.
#8215
#8216
Re: Re: New Nova Engine
Originally posted by EVOLUTION
14.25m/m
14.25m/m
Saw it and shocked it with this.... Isn't like the old MT12 who was the same RS12 but with a longer rod. This engine for sure will turn a little less rpms but with enough grunt and torque to light and blister tires.
Probably our HK spy can give us more info about this.
Robbie: Have more info about this?
#8217
Re: New Nova Engine
Originally posted by hurhur
http://www.mugenseiki.com/nova12engine.htm
#8218
Originally posted by Data
34,000.00 yen !?!?
34,000.00 yen !?!?
Ouch................... 34,000yen=$305.097us.... Ouch
"FXConverter - 164 Currency Converter Results
Wednesday, October 1, 2003
34,000 Japanese Yen = 305.097 US Dollar
34,000 US Dollar (USD) = 3,788,960 Japanese Yen (JPY)
Median price = 0.008969 / 0.008973 (bid/ask)
Minimum price = 0.008917 / 0.008923
Maximum price = 0.009080 / 0.009086"
For over 3 bills, I will definitely go for either Vmax or Rody V12!
does it make sense to all of you guys??
#8219
Re: Re: Re: New Nova Engine
Originally posted by Corse-R
Yep...
Yep...
Maybe i should do what manti does and buy them all.
#8220
Re: Re: Re: Re: New Nova Engine
My head is spinning with all the new engines,i don't know what to get !!!
