Mugen MTX-3
#4996
Re: Re: Re: Re: Weight loss
Originally posted by eddiethefish
But Cartman knows photography stuff. Look at the way he uses the lighting. Another perfect 10!
#4997
Originally posted by RClover
let see if i can earn a hop-up master title..
Alu. Engine Brace
Alu. Cross menber
Hex Drive washers
Alu center belt block
Alu front sway bar holder
Front CVDs
Rear CVDs
Adj Rear Anti Roll bar
4mm chassis
Alu engine mount
Alu Center radio plate support
Super hard clutch spring
Gray clutch shoe
Lightened fly weights
Zac heatsink
Teflon Brake pad
Ennetti disc rotor
Titanium middle shaft
Rear roll bar fasteners
didnt realise i had this much !
Alu. Engine Brace
Alu. Cross menber
Hex Drive washers
Front CVDs
Rear CVDs
4mm chassis
Alu engine mount
Gray clutch shoe
Zac heatsink
Teflon Brake pad
Ennetti disc rotor
Ka Alu. Engine Brace
Ka Alu. Cross menber
Mu Hex Drive washers
Ka Alu center belt block
Sq Alu front sway bar holder
Mu Front CVDs
Mu Rear CVDs
Ka Adj Rear Anti Roll bar
Ka 4mm chassis
FiveStars Alu engine mount
Ka Alu Center radio plate support
Mu Super hard clutch spring
Mu Gray clutch shoe
3R Lightened fly weights
Zac heatsink
Mu Teflon Brake pad
Team Active ventilated/cut brake discs
Sq Titanium middle shaft
Sq Titanium main shaft
FiveStars Ti coated Shock shafts
Sq Teflon Shock Plate 1-hole and 2-hole
Sq Shock plate
Sq Shock adjusting ring
Hashimoto Rx graphite plate
Ka Negative Diff
Ka al bulk stiffener and Graphite Body post Tower 2nd Edition
Sq brake lever
Sq Delrin and Alu Knuckle nuts.
Sq bumper
etc.... I'm tired now , see the pictures for more info...
#4998
I guess I'll have to take a few pics of my car to bring this discussion to an end
#4999
question re clutch
Hello,
When to opt for the stock clutch, the gray, or the red one? Of course one if softer than the other, and I'd just like to know of when to pick which one to choose.
Thanks in advance,
eddie
Thanks in advance,
eddie
#5000
#5001
What I've heard and seen, the red one is the one to go with.
Kinda hard to find though.
I run the stock one and I'm pretty happy with it so far.
#5002
Hi guys,
I was just wondering which parts break most and which parts i should keep as SPARE PARTS? Any must upgrade item you recommand? Seems like Front universal is must have but which brand mort durable?
Thanks.
Thanks.
#5003
Originally posted by US_MATRIX
Hi guys,
Thanks.
Hi guys,
Thanks.
the mugen CVD is the one to go with !!
#5004
Re: question re clutch
Hello,
Thanks in advance,
eddie
Hello,
Thanks in advance,
eddie
http://66.70.235.59/Merchant2/mercha...Code=mtx3up_ct
#5005
Hi guys,
Hi guys,
- Front uprights.
- Rear uprights.
- Rear A-arms.
- Some belts (F/C/R).
This should be the minimum. From this to whatever you want to carry.
Front universals are twitchy, depending the brand you get, durability varies (have seen to snap 2 sets of 3racing universals in one day without brushing boards). Go for the Mugen ones, are expensive but worth the investment.
#5006
Re: Re: question re clutch
I just found them:
I just found them:
#5007
I just found them:
I just found them:
#5008
Eddie,
Speedline carries them as well. Also, whoever sells Delta parts should be able to get it. If memory serves me, it's just a rebadged Delta shoe anyway. I run them in my cars, they're very nice!!!
#5009
Hey BRING IT....Don't SING it!
#5010
I need an engine that last forever without changing con rod
