Mugen MTX-3
#3901
Try to use a little less caster and or 1-2 deg rear tou before messing with the rear diff. A softer rear diff will give you a little more turn in but u will lose rear stability under braking and it will be harder to go on power hard after the turn (if the grip is hi)
#3902
something like this...
the track layout is about like this..
#3903
Re: something like this...
#3904
Less caster is good for entering a corner, but how about when powering out of the corner?
#3905
Re: Re: something like this...
Originally posted by TSR6
Nice track, What are the barriers made out of? Just curious..
#3906
We only have perminent tracks here and none is anywere near that small... I would go with lesscaster and if possible a front diff so you have real braking
#3907
race is this weekend so i am afraid of losing out practice time if i have to learn a new Full Diff driving style...
#3908
Re: Re: Re: something like this...
cant really figure that out too.. could be made of PVC
#3909
yeah..i think it should be..
#3910
the track doesnt look low to medium traction. and it looks smooth and flat too.
#3911
#3912
The black diposites on the alumminum piston usualy means trouble with heat above 250 F'.
For me that is 50 F' hot and I get all the power in 200 that others get at 250. so you probubly need to tune properly or add fuel to the mixture.
Got this off from another forum, is this guy telling correctly?
I have those dark brown deposit on the piston head while my pipe still spitting fuel from stinger, and the car not very fast.
Is that caused by too lean..?
#3913
arr...sorry, i meant the track i'll be racing is similar to this in its size...not this one...
#3914
Try increasing rear droop a little to get the weight to the front while off power or braking.
#3915
- Too much oil (castor oil) on your fuel.
- Too high compression chamber (run at low compression).
- Too much heat.
- Too many gallons trhu the piston (this shouldn't be your case).
