Old 09-07-2005, 09:29 PM   #15901
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I think I was talking to someone about a rubber tire set up when I was saying use the Black shoe. When on a high bite track use the grey or red As far as spring I use the gold for most applications, I usually have about 2 full threads showing behind the adjustment nut.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 09-07-2005, 11:41 PM   #15902
Originally Posted by MARKANO
Mr SlotMachine
Just wondering what is the reason to use the stock BLACK clutch instead of the option GREY / RED?? I thought the optional Gray/Red clutch will provide less "slip"?
What is the ideal spring that come with the clutch set, Silver or Gold.
Thanks.
He is talking about using the black clutch shoe for rubber tires. It allows the clutch to slip and prevents the tirers from breaking loose. This can also be used to fine tune the clutch for low or hight traction tracks.
ATXPro4 is offline   Reply With Quote
Old 09-08-2005, 12:11 AM   #15903
Mr Slot, yes you did mention the rubber tires, me bad.
Just another question, is it a good idea to use the longer allen screw instead of using the shorted screw with the 3mm ball for the clutch shoes which was posted before.
MARKANO is offline   Reply With Quote
Old 09-08-2005, 06:01 AM   #15904
Old 09-08-2005, 07:45 AM   #15905
i have an MTX-3 up for grabs if anyone is interested. it's loaded with spares and a serpent starter box. pm for details.
flyingfox is offline   Reply With Quote
Old 09-08-2005, 08:43 AM   #15906
asw7576's Avatar
He meant this :
http://www.rctech.net/forum/attachme...chmentid=85041
I haven't change the 2 speed clutch since 4 or 5 months. Make sure to perform periodic check before race day.
Tigthen SK4x8 until tiny gap appeared. If you tighten the screws until TO233 can't twist left & right, the transition from 1st to 2nd feels smoother. And vice versa.
Old 09-08-2005, 11:04 AM   #15907
If you use the longer one you would be better off, I use the short and have never had any problems.
I use the Serpent assembly trick, Screw the grub screw in from the other side, Stick your wrench in through the hole and unscrew the grub from the bottom side like you are taking it out instead of putting it in. That way the screw will never back out all the way by itself.
Old 09-08-2005, 06:34 PM   #15908
Originally Posted by afm
I totally agree with you. We used to race with BSR's, but unfortunately they are not legal sized for sanctioned races, and we had to search for something else...that is how we ended with PMT.....I wised BSR would build a legal sized tyre...I'd go back to them even it they are pricey.
AFM
When would you like to have some? Is there any tolerance to the 26mm width, like can it be 26.30? I ask that because on our current design the rubber overhangs the wheel on the inside of the tire. I can make them on 26mm 5 spoke wheels. If there is no tolerance I will have to narrow the wheel some.
John Foister is offline   Reply With Quote
Old 09-08-2005, 09:21 PM   #15909
gentleman81's Avatar
Default rear block wrap up
so if i am racing on a track with low traction i dont want alot of roll because it will cause more sliding. so i should use the C block or B versus the A?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 09-08-2005, 09:45 PM   #15910
rocca30's Avatar
try the C block, should help
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 09-09-2005, 06:05 PM   #15911
Originally Posted by gentleman81
so if i am racing on a track with low traction i don't want a lot of roll because it will cause more sliding. so i should use the C block or B versus the A?
Don't worry so much about the roll factor, the C block will give more traction.
Old 09-09-2005, 09:31 PM   #15912
my race is sunday so i will see how the C block works for me with the proper set up. thanks again
Old 09-10-2005, 08:16 AM   #15913
Redvet79's Avatar
I Use C block Works Great
Redvet79 is offline   Reply With Quote
Old 09-10-2005, 10:57 PM   #15914
freefallmarine's Avatar
Get this, My wife and I raced on a loose concrete track this weekend and her car was everywhere except where the line was, so i gave the prospec some rear toe in, and lowered the rear shock one hole and tested it between heat's. Better but still a little loose. Then I noticed All of the Mugen guy's had there rear sway bar dissconnected! So, being (Monkey see-Monkey do.)I removed our Mugen's rear sway- And wow! it stuck great! Anybody else tried this? I recommend it on concrete and loose-unpreped track's. Just my 2 cent's. C.
freefallmarine is offline   Reply With Quote
Old 09-11-2005, 02:03 AM   #15915
asw7576's Avatar
Good on you..... now I learn my ABC
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
Mugen 5T Chassis, Mugen 46 Tooth Pinion, Associated Ride Height Gauge bretzkej R/C Items: For Sale/Trade 1 08-19-2007 05:31 PM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 04:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 08:31 PM
