Old 06-28-2005, 01:50 PM   #1
Default heat problems
hi i have an kyosho alpha 3 rc car but when it starts after 5 minites the heat gets higher and then its stops all the things i use are those from the package
charis is offline   Reply With Quote
Old 06-28-2005, 01:54 PM   #2
Francis M.'s Avatar
hi charis you could richen up the fuel setting by turning the carburator counter clock wise. about 1/8 turn at a time. Also as a reminder you might want to put a hole on your wind shield approx the size of you r/c wheel to let air in for the engine.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 06-28-2005, 04:07 PM   #3
Send a message via AIM to The evo guy
that or you can make it sexy by putting in a real grill and cutting the back up a little so you dont get lift in the car and it cools better
The evo guy is offline   Reply With Quote
Heat problems: HPI Rally RS4 Mooshu Beef Electric On-Road 6 05-17-2008 07:29 AM
Heat or Ream? performula Nitro On-Road 1 05-02-2006 11:30 PM
Cold Heat ZeroCooL Electric On-Road 62 01-10-2006 05:48 AM
Heat Sinks ThaFlash_LA Electric On-Road 1 08-06-2004 10:35 AM
When the heat is on Cole Trickle Electric On-Road 6 04-10-2003 05:53 PM
SEO by vBSEO 3.5.0
