WRC Racing - 1:8 Pan Car Forum >
Like Tree1Likes
Old 04-22-2014, 05:56 PM
  #226
Questions??
Any tips to build a no leak WRC Gear Diff? I've built numerous sealed Gear Diffs for Xray, Yokomo and even a couple of Awesomatix. I used Green Slime and Permatex Copper Gasket Seal like I have with electric cars but my first attempt at a WRC Diff wasn't as successful.
What are other WRC owners finding?
ElliotCanada is offline
Old 04-23-2014, 04:25 AM
  #227
gary47's Avatar
When built mine the rubber o ring broke, so I used permatex ultra grey ridged high torque rtv silicone gasket maker no leak yet and been in since built in november
gary47 is offline
Old 04-23-2014, 08:32 AM
  #228
John - also had an issue with the o-ring squeezing out , increasing the chamfer inside edge of the pulley seemed to cure the problem.
Rick Davis is offline
Old 04-23-2014, 01:50 PM
  #229
Taylorm's Avatar
U bought one also??... Looks like it's me vs
team WRC
Taylorm is offline
Old 04-23-2014, 08:35 PM
  #230
MrHistory's Avatar
Thanks for the tips guys! I have built a few and noticed a little squeeze out and other times they've gone together well. I may try Rick's method. Did you sand paper the plastic?
MrHistory is offline
Old 04-24-2014, 05:48 AM
  #231
Jason - Nope used a swivel deburring tool on the inside corner of the pulley - there is already a chamfer there I just made it a little larger - need to be a a little careful , if you get carried away pretty sure you will have no chance of sealing.
Old 04-24-2014, 12:33 PM
  #232
mcsquish's Avatar
team WRC
If you want, I have a engine for sale that should help you go faster.....
mcsquish is offline
Old 04-24-2014, 01:35 PM
  #233
Taylorm's Avatar
Already bought brand new.. Thanks.. Scott..
Taylorm is offline
Old 05-18-2014, 07:21 PM
  #234
gary47's Avatar
Default diff problems
Hi Jason , ran car in Toledo this week end ran good just feeling car out but in last qualifier had car hooking on me, after some time looking at car found the out axle gears stripped teeth off both sides about 3 on each side. Has any one else had this problem?. Other than that car worked good for first time out for year.
gary47 is offline
Old 05-25-2014, 07:18 AM
  #235
gary47's Avatar
Is Jason still around? asked question for about week no answer at all sites he was on?
gary47 is offline
Old 05-25-2014, 09:06 AM
  #236
MrHistory's Avatar
Sorry I didn't see your post. I have not seen this happen before. Lon mentioned you had this problem and I told him that you are welcome to call or pm me and we can try to figure out what is the issue. So feel free to pm your email address and we can get you up and running, although I was under the impression that Lon had gears he offered to give you.
Either way, feel free to reach out. I'm happy to help. Also, you can email me through www.irwinrc.com
This is the best way because I see my emails right away.
Old 05-25-2014, 09:12 AM
  #237
MrHistory's Avatar
As for as building a no leak diff, I would recommend Rick Davis's trick. He is a wealth of knowledge and trust that his solution works. Personally I have not had issues with the diff. I ran the same one all last season and it's still in my car and working fine.
Old 05-25-2014, 09:14 AM
  #238
MrHistory's Avatar
Gary, it would be great if you can share a link for the oring gasket you found for the diff. Thanks!
Old 05-25-2014, 01:55 PM
  #239
gary47's Avatar
I picked mine up at HOME DEPOT IN GLUE SECTION BUT ANY AUTO STORE SHOULD HAVE IT. Did you get my email about diff gears?
gary47 is offline
Old 05-25-2014, 04:08 PM
  #240
gary47's Avatar
JASON when email me have some pictures send you about stripped parts.
gary47 is offline
