Old 06-06-2006, 11:43 AM   #31
Hello from France,
My TG10Mk2 2006 version.
romuald31 is offline   Reply With Quote
Old 06-06-2006, 10:12 PM   #32
spenzalii's Avatar
Send a message via AIM to spenzalii
It does look a lot like the FW05 and CD3 (even though Ofna managed to put a box for the receiver and a spot for the battery so there's no wires showing). If you can get Ofna parts, try a set of their 0.8 gears, they should work. I'll try to track down a setup I use at my track in the morning.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 06-07-2006, 01:58 PM   #33
Send a message via AIM to barry Send a message via Skype™ to barry
ANYONE USING THE BLACK(HARD) CLUCTH SPRING? CAN I KNOW HOW MUCH GAP IT SUPPOSE TO BE FOR SPRING NUT TO TIGHTEN AND THE PLAY OF THE CLUCTHBELL
barry is offline   Reply With Quote
Old 06-07-2006, 09:51 PM   #34
spenzalii's Avatar
the spring will depend on the motor. Usually you atart with .5mm from the thread to the nut and adjust it from there.
As for the clutch gap, there's a good thread on here on how to set the centax clutch. It's a must read.
Old 06-08-2006, 06:50 AM   #35
JLock's Avatar
I have had the chance to run the car at my local club track. The surface is concrete so rubber tires with inserts are the wheels of the day. The car is awesome once you add the front sway bar and change the shock springs from the stock yellows to the whites with 50wt shock oil. I did leave the yellow sway bar attached. Mine is paired with the Mugen X-12 engine and has incredible take-off power from a dead start. What I am amazed with is the off-power ability of the car. The car has that NTC3 off-power free-roll in which you can maintain off-throttle speed into corners and power up coming out of corner strong. I am very pleased with this version over the Mk.1 is has replaced (I have on of those too). Now, Tamiya needs to market this car more as a player in the touring car race game. It deserves at least that much.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 06-13-2006, 10:12 PM   #36
This is all great news!
I just bought the PRO kit with Helios radio/spectrum and EB modified OS tz
I cant wait to take it racing and let you guys know how it goes.
Cheers.
Scoobs is offline   Reply With Quote
Old 06-17-2006, 07:56 AM   #37
Carbonfi_dragon's Avatar
Default Woooah
The black clutch spring is really hard! Often ends up stalling the engine with normal running as the clutch biting point is a very, very fine line...Unless every time you accelerate from a standing start you are going 70%+ accel., Slow starts are hard...
The medium clutch spring works best for me, I have tried all three. My TG10-Mk.2 PRO is fully tuned, 100,000JPY+ spent on the car, have upgraded the car with every product I can find other than:
Racy carbon upper plate, Racy aluminium racing chassis and Racy carbon front plate, - Hopefully will arrive this Thursday! - Also upgrades not included in the pics - TRF Special blue damper set
Pics can be found here: http://www.personal.leeds.ac.uk/~eas4cpm/
Here are my car specs:
Main equipment
-OS Factory Tuned TZ.12(P) 5-port engine (2.1cc output, 13.8mm bore x 14.0mm stroke, 5,000-40,000 RPM, 1.62PS @ 34,400RPM) weight 224.5g, black heatsink replaced with silver item.
-Running on Tamiya TG-30 (30% nit. fuel)
-Using OS P7 "medium" turbo glow plug.
-Upgraded large air intake (EAST E5054 for .12-.21 engine)
-X2 Futaba 53050 servos, 48.8g each (10.16sec/60 [email protected], 6.5kg/[email protected] torque).
Upgrades included in Pro kit
-Tamiya full ball bearing set OP.8, OP.30, OP.65, OP.66, OP.126
-Tamiya front one way differential set OP.885
-Tamiya 2mm carbon upper deck 2024003+9444509
-Tamiya 2-speed gearbox
-Tamiya sponge tyres: F(No.37 - (OP.742): 26mm wide, 65.5mm diameter sponge. R: (No.35 - (OP.745): 30mm wide, 65.5mm diameter sponge
-Tamiya TM-9 race-tuned muffler
Additional upgrades
-Tamiya battery and receiver rubber bag set SP.194
-Tamiya 32mm fuel filter GE.5
-Tamiya anodised engine mount OP.797
-Tamiya full titanium screw set, 97pcs total - 1/2 weight of original screws, overall weight saving of 33g OP.740
-Tamiya blue anodised aluminium (1mm lower) damper down retainer set (4 pcs) OP.876
-Tamiya hard front spring set OP.751
-Tamiya hard rear spring set OP.756
-Tamiya racing clutch spring (medium) OP.737
-Tamiya hard rear stabilizer rod OP.739
-Tamiya adjustable front stabilizer OP.796
-Tamiya clamp type aluminium wheel hubs (6mm thick type) OP.569
-Tamiya universal shaft set pair (x2) OP.795
-Racy carbon front body mount brace RTG.253
-Racy carbon rear body mount brace RTG.254
-Racy carbon front damper stay RTG.269
-Racy carbon rear damper stay RTG.270
-Racy drilled stainless uprated brake disc RTG.255
-Square lightweight front centre universal shaft STX.22F (replacing Tamiya F+R strengthened prop. shaft OP.888)
-Square lightweight rear centre universal shaft STX.22R (replacing Tamiya F+R strengthened prop. shaft OP.888)
-Square titanium suspension balls (8 pcs) - standard parts 3.39g each, Square parts 1.88g each, 12g overall weight saving STX.80
-Square aluminium rear deck holder STX.37
-Square aluminium anodised output shafts (front and rear) STX.6
Carbonfi_dragon is offline   Reply With Quote
Old 06-29-2006, 03:55 AM   #38
Rootman17's Avatar
Default Parts for mk.2
Does anyone know where to get parts for the Tamiya TG10-MK.2, besides Tamiya themselves? I tried RCMart but they have limited parts. Also I probably won't shop from them again because I placed an order with them, and then 2 days later they decided to tell me the were out of stock on those parts. I got to race, don't have time wait!! I saw those Racy upgrades, they look awesome. I was thinking of switching cars if I can't find parts for this car. Please Help!
Rootman17 is offline   Reply With Quote
Old 06-29-2006, 06:13 AM   #39
I'm know that BoyToys.ca sells lots of Tamiya stuff and always has stuff in stock, so you may want to give them a call and see if they are able to help you out.
BTW...here are some new pics of my Mk2 Pro..
So fresh and so clean!!
Cheers,
Sal
Old 06-29-2006, 04:02 PM   #40
Rootman17's Avatar
Default Parts?
What about in the U.S.? BoyToys.ca is high shipping costs to me in the U.S.
Old 07-03-2006, 08:16 AM   #41
Racy, Square, M.Factory...Eagle also brought out a full set of alum. F+R uprights, upper and lower sus arms. They rock!
These parts are easy to get anywhere in Japan, and cheap. Try some of the J-shops out there
Guess they might kill you on prices though...Dead easy and cheap to get bits for the car over here.
Old 07-06-2006, 06:58 PM   #42
Bump!
I need some help sourcing a Racy Chassis for my Mk.2 Pro and other high end hop ups that are hard to get, or not avail in USA/Canada.
I would be willing to pay for someones time if they can assist me in getting the parts im looking for.
Thanks!
Sal
Old 07-06-2006, 07:57 PM   #43
shiston's Avatar
For Racy stuff get it from http://www.racefactoryrcp.com/
but I understand that there is a current shortage on Racy stuff .
Hang around......we'll talk some more
shiston is offline   Reply With Quote
Old 07-06-2006, 08:19 PM   #44
Yeah thats what Chris told me from the same place you directed me to.
I have all the parts I want on order, but no chassis and thats the most important one for me.
Someone in Japan, or elsewhere help a fellow Tamiya brother out.
Cheers,
Sal
Old 07-08-2006, 09:01 AM   #45
Join the club. I live in Tokyo Japan and the Racy factory has halted production of the lower and upper chassis plates. So I tried Race Factory in Australia, and guess what, they have none left (I made an order)...And they will not be getting any in, because as I know they are out of production.
Chris of Race Factory claims that this happened earlier with the TG10 parts and Racy started production after a similar halt, replacing the old parts with some different upgrade bits.
Let's wait, I am waiting on my order from Race Factory and can get in contact with Racy here in Japan whenever I want.
These parts are unsourceable anywhere in Japan or Australia. May be a few of them habging around on shelves in Guanghuajie in Mongkok, HK but who knows.
Best of luck with those parts...
Tamiya TG10-MK.2 shiston Australia For Sale/Trade 6 08-27-2008 02:17 PM
Tamiya TG10 MK1 ????? RollingThunder Nitro On-Road 2 02-11-2008 04:17 AM
HPI rs4 3 OR Tamiya Tg10 R bumm_off_street Nitro On-Road 2 07-10-2006 03:55 PM
FS: NIB Tamiya TG10 MK2 + hop ups kalani R/C Items: For Sale/Trade 1 11-22-2005 05:50 PM
Tamiya TG10 MK1 Pro chorner R/C Items: For Sale/Trade 0 10-10-2003 03:43 PM
