Old 09-30-2013, 09:46 AM   #16
lagos's Avatar
the xray caster blocks dont fit inferno style suspension ok , they fit on JQ , but you have to use caster block + hubs + xray universals + ballbearings ....
with this combo , i felt the car was sheet with front tires and continuous with a good corner entry and corner speed ...
JQ - THE Car GT
Inferno GT RR
Thanks to ALPHA RC TEAM !!!
lagos is offline   Reply With Quote
Old 09-30-2013, 09:56 AM   #17
lagos's Avatar
I would greatly appreciate if anyone had any information from other models of 2 speed transmission gears which can also be used ... The JQ yellow chassis is very tight , but offers adjustments on engine position end central diff position that helps a lot ... as I only have the kyosho 2 shoe type model that i like a lot , I stuck to it in car conversion ... any tip is very welcome ..
JQ - THE Car GT
Inferno GT RR
Old 12-31-2013, 06:37 PM   #18
Hi lagos, thank you for sharing your excellent mod and congratulate to your win.
I've been thinking to custom mod a 2 speed transmission and would like to seek your help for some measurement below:
1. length of the 2 speed shaft (part no. KYOIGW008-01)
2. diameter of the 2 speed shaft
3. outer length of shaft measure from drive cups end to end (measurement A of pix)
4. inner length of shaft measure from bearing to bearing (measurement B of pix)
5. Thickness of bearing
I appreciate very much if you could help me out on these measurement. TIA
ferrariGTR is offline   Reply With Quote
Old 11-24-2014, 10:58 AM   #19
lagos's Avatar
i`ll take the mesurements for you ok ... and iŽll try to take some other pics to show details too ok ... see you
JQ - THE Car GT
Inferno GT RR
Old 12-31-2014, 01:43 AM   #20
Fluke's Avatar
bumping this up because i'd like to know the mesurements as well
Fluke is offline   Reply With Quote
Old 02-20-2015, 07:45 AM   #21
n.e.r.d's Avatar
Hi Lagos, I'd like to know the measurements of the IGT 2 speed transmission too..
Will be waiting, thanks!
n.e.r.d is offline   Reply With Quote
