1/8 On road
1/8 On road
Im looking to get a 1/8 scale on road. I wanted to get some advice on the ups and downs of some of the 1/8 kits out there. Should i got with hpi or kyosho mugen etc..?
I'll give you the same advise everyone gets,look for the best local parts availability and carry plenty of spares.If you're new and you run it on track you're going to break it and there's nothing more frustrating than not being able to fix it. 1/8 scale is kind of like Indy cars in that there are only two types of drivers,THOSE THAT HAVE BROKEN THEIR CARS AND THOSE THAT WILL BREAK THEIR CAR.The 1/8 cars are all very good it's all personal preference and product support.
mrx 4 mugen seiki
go with the new ,mrx4 from mugen.
wy, it is a rely good car,and the spare parts the most importend thing, you can get them evrywhere.
What they said....
Or...you could get an RTR for under $400:
http://www.rctech.net/forum/showthre...threadid=47469
It's a great deal, I've been pleased with mine. My LHS stocked up on parts, so local support is good. Read through that post, it should give you a good idea of what it is...
Are you sure it's RTR? I don't think it comes with engine or pipe neither. Forget servos.
I was checking myself the distributor's site, unsure what's included I believe engine, pipe, header is not. Tires probably are. But I might be wrong.\ or unless RTR means something else in 1/8 world.
Typical serpent mugen kyosho chassis itself are average $500-$650 each. Engine $300 +/-, pipe, $80, high end servos $90 each x2, then radio of your choice $250 +/- plus other little thingy.
My suggestion, buy a used car...a lot cheaper. (Serpent 950 used around $300, compare to the new one $600)
It is a true RTR: http://www.happytimehobby.com/cars/xr80/index.html
RTR is designed to be the fastest, best-handling ready-to-run car of any scale. Borrowing technology from its brother, the XR/8, it doesn't skimp on features. Only a few parts are changed to make the car more affordable for the parking lot racer in all of us. The engine is started via a Quick-start shaft attached to either a cordless drill or one of our own Power Starters...no pull-start to break or gears to strip! If you want to go racing, all parts are fully upgradeable to XR/8 specifications.
XR/80 RTR Features:
Machined 6061 Aluminum Chassis
PRP .27 Engine (2.7hp, 40000rpm)
Quick-start shaft drive starter system
2ch AM 75mhz Hitec Aggressor radio system
Anodized Aluminum radio tray and shock towers
3-shoe clutch with lightened flywheel
Shoe-type 2-speed transmission
Hardened Quick-change axles
125cc fuel tank w/internal filter and splashguard
Unique wheel design (Serpent compatible)
Threaded aluminum shocks
Pre-cut, pre-painted GT1 body (Blue or Red)
It's still a better idea than a used car that's been through who knows what...
XR/80 RTR Features:
Artificial-I, what can you tell us about your Proceed? How long have you had it, and how has it held up/performed?
I could still get parts for my old RS4 Racer 2 not long ago, are the parts for the Proceed being discontinued? Or are they just being carried by fewer dealers?
picco integra.
here is my picco integra 1/8 scale...
With all the great 1/8th cars out there..........I don't know why HPI Proceed is within your range of 1/8th choice...?
I would say Serpent / Mugen should be your top choices, then Kyosho a close 2nd (due to part support no longer be under GP or TOWER).....there will be no 3rd choice...(my opinion).
P.S....if money is no object, squeeze in SMP slide V5 on your 3rd choice.
Originally Posted by Scott Fisher
Don't forget about Delta XP4... I know it is very very similar to the Kyosho.
