high quality servos?
#16
warranty
By the way HITEC does have two year full warranty.I no longer use any of their servos as I had a lot of problems with their mid range servos on throttle with a return spring.After warranty repairs on their digitals I had no further problems. The KO however is so much better both on speed, sensitivity, and centering that I use them (HITEC) only as play car servos.
#17
Originally Posted by factory racer
thanks guys for all ur input.....im really considering the airtronics one...i dont really remember the number of the servo but it has a blue heat sink and it has 125 oz of torque and .07 transit time.......or the futaba s9451......either one of them i will chose from .....thanks alot guys
Mike.
Mike.
#20
Originally Posted by Scott Fisher
Just the opposite. Do not use digitals on throttle /brake.
#21
#22
is the airtronics servo with the blue heat sink any good.....it says it has .07 transit time and 125 oz of torque.....is airtronics also reliable ..................
#23
Originally Posted by Jari
Can somebody explain why not digitals for throttle/brake?
#24
I like Ko 2344 or 2364. I think digital servo is better in general due to consistent adjustments and no overshoot. Analog servo, before any arm movement, will have to have a bit of backlash. Also, when it stops, it will have overshoot. These flaws are mainly because delay in the feedback loops. On the other hand, digital provides very frequent position update and much accurate neutral position. I agree with you, using digital servos at throttle/brake might have problem. But, I think on the newer ones this has been much improved.
#25
#26
There has been improvement in the digitals since they first came out, but the reason they were not to be used for throttle/brake is as follows. One of the big advantages to digital over analog is the fact it "pulses/adjusts" its position 3 times more often than an analog which is why they have holding torque 3x the actual rated torque. The problem with this on throttle/brake is really on the braking side. When braking, the servo is stalled and basically trying to move, but unable to. That extra pulsing causes the servo to overheat/fry itself. That is basically why manufacturers were advising analog on the throttle. I know my terminology may be incorrect, but the idea is correct. Either way, every digital I ever had fail was on the brakes, and I will just stick to using analog. Also, I don't really see any advantage to digital over analog on the brakes. There are obvious ones for the steering but not really for the brakes. That being said, why risk using digital for the throttle?
Indeed futabas s9450 now has the s9451 so im guessing if you have the newer futabas or digitals. Your ok?
Im glad right now I can use either or and I use only digitals on the steering because of my budget.
#27
servos
Main reason not to use digital on brake is they have a much higher current draw.Airtronics is a very reliable servo other than the primary plastic gear,if or when it fails you will find nobody stocks it.If you run your servo saver stiff it is not very forgiving.My 2cents KO.
#28
i just order ko propo 2363 and 2364 for my upcoming serpent 710.anyone have it???how does it perform???
#29
how about futaba 3050. any input for this servo. it is digital and has 90 oz / 0.16s at 6.0v. can I use this for steering in my v1rr nitro car?
#30
