Engine bogs down 0-100% throttle
my buddys T 3.0 on his rs4 Bogs down and looks too lean when you mash the throttle 0-100% but when you ease into full throttle its fine When you hold the car up in the air it doesnt seem to do it, did the pinch test and scored a 3-4 sec, idles perfect filter seems good the car does seem to roll quite a bit at low idle so im thinkin he may have a clutch problem.. think that could be causing it?
Shoot any suggestions you can.. thanks
Matt
Matt
Yep, probably a bad clutch spring, they don't last forever. It can be impossible to get the tune right with a bad clutch.
tellin him to pull it off right now!!! thanks.
the weird part was when we richened it out a whole half turn it didnt seem to do anything lol
