Old 04-20-2013, 11:04 AM   #1
MiamizFinest's Avatar
Trader Rating: 37 (100%+)
Default 8th Scale Nitro Guys, What Body Has The LEAST STEERING?
I have a brushless mxr4r I use for high speed passes, the car runs good I get it into the triple digits easily and have no problems with it. I'd like to go faster and I'm sure my current serpent body will hold up fine, but I wanted to get others opinions on which body's are less senestive and which body's are known to push more than other?
Opinions? comments?
-= Made In Dade =-
MiamizFinest is offline   Reply With Quote
Old 04-20-2013, 11:31 AM   #2
wingracer's Avatar
Trader Rating: 21 (100%+)
If you can find one, the old Parma R8 body was super stable but pushed bad in fast corners unless you mounted it WAY forward.
Pretty much any body should push at speed if you mount it as far back as you can.
Sean. Certified speed crazed mowron.
Team Shepherd USA
wingracer is offline   Reply With Quote
Old 04-20-2013, 12:20 PM   #3
JamesHealey's Avatar
Blitz R18 v1
Mounted as far back as possible with gurney as high as possible.
Will push!
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
SEO by vBSEO 3.5.0
