Old 03-22-2013, 01:32 PM   #1
Default Fusion 28 to 100mph
If I was to take a LRP 30 or 32 motor, send it to be modified with AB Mods and dropped it in a Fusion 28, could I hit 100 with that setup OR would it be better to modify the Picco 28 Turbo motor that the car comes with?
I also heard that Schumacher sells a set of larger wheels that once installed, should get you to 90 stock (theoretically). Anyone heard of these or have tried them? Since they 12mm hexes, I imagine they would work on any other 1/10 nitro out there.
jude26 is offline   Reply With Quote
Old 03-23-2013, 01:59 PM   #2
If you are a speed demon the Fusion is not a good platform to work with because of the way the drive belt is designed too wide too long and too heavy. Get a HPI unless you have alot of money you want to speed on making the fusion fast.
nitrohead5300 is offline   Reply With Quote
SEO by vBSEO 3.5.0
