Old 05-03-2005, 05:18 PM   #16
Cat Skinner's Avatar
Back-up and make sure you are on the right track.....
Are you getting into the right car--parts availability, set-ups from other racers, what car is being run the most there? I'm not trying to talk you out of a kyosho it's a good car.......it's just that a lot of factors go into making the right choice for a first car (I don't count RTR as a first car, my bias). The right answer would be different based on geography alone (my opinion). I personaly bought the wrong car the first time, because I didn't know any better at the time, also the second (when I should have known better).
I think you may be going about this the wrong way, your best source for cheap r/c stuff that has enough quality to be raced are in the hands of your own local racers. If you are planning to race than there must be a track near you. Have you spent time there asking questions and getting to know the racers? They should be the ones to help you in getting your stuff together. At the track I race at most of the more experienced racers step up to help out the rookies that are new to the hobby......(advice, parts, good deals)
Transitioning from rookie to expert is so much more about the help you'll get from good racers than it is about the equipment. You shouldn't miss this opportunity to seek out verteran r/c racers that are willing to help and get to know them. I think the whole problem that you're having now with trying to use an existing pull start motor to save money and avoiding short term costs would be worked out with just a little help.
Regarding the question of starter boxes or pull starts I agree with onnetz 100% about trying to cut cost like you are suggesting, it'll come back to bite you...... your chasing your tail if your trying to make that motor/chassis combo work and you don't know what an SG shaft is.
Any veteran r/c racer that does not see the long term benefits to this hobby of helping out rookies and bringing in fresh people has missed the boat. If you were at my track, and I believed you to be sincere I'd give you one of my last years MT12's and let you borrow my starter box till you could get one.
Best of luck and sorry for being long winded.......
Cat Skinner is offline   Reply With Quote
Old 05-03-2005, 05:35 PM   #17
ntc3freak's Avatar
dont get pullstart!!!!!u need to open the body to start the engine(if u dun cut holes),u get tired arms after a day of bashing,the strings need to be replaced,the one way bearing needs to be replaced.get a good non pullstart engine and a starter box and it will save u later on.and it is so much easier to start and engine with a starter box.put the glow igniter and push the car down on the starter box.how easier can it get????
ntc3freak is offline   Reply With Quote
Old 05-03-2005, 05:39 PM   #18
dodo's Avatar
Send a message via Yahoo to dodo
hehe, this is personal experience.
if you plan to go racing in the future, you will still end up buying a good engine. I think if you use RRR with a pull start engine, won't the car be 'under-utilized'?... just my 2 cents....
R40, FW-05 or RRR? certainly RRR for me... actually from what I heard and witnessed all are equally good, just that R40 and Fw05 has been around for quite some times, RRR being the latest pro kit in the market.
if you use washers to build the proper height for the engine... not sure whether this will work in the RRR as this will bring the pinion up and in front of the spur gear, thus the mounting hole on the engine mount will be shifted towards the front (am i right? please correct me if i am wrong)
my suggestion is get whatever pro kit you want with an engine (OS or STS D3R/D5R) engine shld be good enough. Then slowly add on things that you want like starter box etc. I am doing that myself. But one thing you have to bear with it and need to ask around for kind soul to let you use their starter box (sure there are plenty of 'em on track).
you are in singapore right, just come to HPRC on the weekend, i'm sure there will be people playing.
dodo is offline   Reply With Quote
T-maxx pull start hard to pull.. t-maxx_boi Monster Trucks 1 04-28-2006 06:03 PM
Wanted Pull start/roto start for collari .30 seajj2 R/C Items: Wanted to Buy 5 08-31-2005 04:51 PM
Pull Start? Roto Start? or Starter Box? jamiekulhanek Electric Off-Road 3 09-09-2004 12:50 AM
Exactly how do you start a pull-start motor? <Don't flame me because I'm dumb!> Vyrus Track Locator Forum 1 08-20-2004 05:39 PM
NTC3 pull start to non-pull question SeventyGTX Nitro On-Road 4 02-16-2004 07:05 PM
SEO by vBSEO 3.5.0
