What happened with my gears? TC3
I was showing my car tonight to a potential buyer and during the run the car shut off. After closer inspection it appears that my gears snapped out of whack. I also pulled out a couple springs?
The engine on the car is a Nova Rossi C12 if it matters and here is a picture. Please help so I can trade this car. http://i163.photobucket.com/albums/t...ps850dd9c8.jpg |
It looks like the clutchbell came off and it bent the second.gear bell on the transmission. Did you loctite the screw holding the bell to the engine?
I am very new to this and recently purchased this car about a month ago. I took it to a local hobby shop to have them give it a 1 over and they claimed all they had to do was put in a new glo plug. What do I need to do to get this running again?
Originally Posted by Pintobean11
(Post 11741654)
You will need to tightened down that clutchbell screw and loctite it. Might also want to look into a new 1st and 2nd gear. Should be a cheap fix. |
Your heat sync looks like it also was put on wrong. The notches for the engine mounts are facing the front and rear not on the sides.
Have fun driving. Ive had the same thing happen I once |
Originally Posted by esckalayd
(Post 11741985)
I see you are in central florida. Did you happen to go to Superior Hobbies? These guys are the best in the state if not one of the best hobby shops in the U.S.
(Post 11742061)
I initially took it to Graves but have been to Superior. With my little knowledge in RC's but willingness to try anything, could I fix it?
http://www.teamassociated.com/pdf/ca...tc3_manual.pdf Look at page 6 and 16. Also, for more information go here: http://www.teamassociated.com/manuals/NTC3/ With these two resources i am sure you can fix it. If you are still struggling, go into Superior and tell them you are looking for a little help. Whether its Andy, Mike, Seth, or whoever, someone will be able to help you out |
Originally Posted by tubasteve
(Post 11742049)
I was able to get everything taken apart. My problem is that somehow the clutch shoe and spring came loose causing the gears to move. I am taking the clutch shoe and spring to Superior to hopefully have them help me out.
(Post 11742736)
