Anyone still racing 235mm 2wd?
finally went with my gut and bought a mugen avance.
i love the look of this scale.
i'm curious if anyone does engine mods to big block 15's.
I think there are at least 2 classes of 235 4WD under MidWestSeries on each stop...........still, I will not give up the Impact unless Serpent is stop making parts for that car....
But getting big block 15 for this car is not easy...........some ppl are using small block 15 or 18 onto the car....
how do you fit a small black .12, .15, or .18 into a 235? the engine mount holes dont line up for the small block engines. are you guys getting custom engine mounts for these cars?
you can get big block 15's from at least one source. rb still makes them in the 6 port turbo non mod and a roddy mod. i got mine from ashford hobbies but they do not stock them , they order them from france and it takes a while to get over here. 235 2 wheel might be gone but it looks like we will have a decent class size in 1/10 open at tsrcar in hamilton, ohio.
From current performances on the track I would be as bold as to say that a good .12 small block with BRB P/S set in it would be a match for any large block .15.
I am thinking about doing this next year. Want to run 235mm again before it dies off completely in the UK (only about 30-40 in total)
or i could have Top Gun 777 modify my big block .15 . trying to work something out with edward cuz i really want a more powerful engine in my car. its too bad you guys dont product P/S set for big blocks (demand is for small block 12's, unfortunately).
But the weight savings from the small block make up for it.
http://www.mytsn.com/products/product.asp?prid=4047
Don't know if this will fit other .15 small block engines made by Novarossi, NovaMax and RB...
thanx initial d.
unfortunately it wont fit my avance. i checked the chassis holes and the serpent ones on the 835 are more closely spaced than that on the avance. its a good idea for 835 owners though.
235 motors
Uriah Murnan will modify a big block 15. I sent my rb down to him today. he has a thread in this section.I ran one of his modified mt 12's last year and it was a powerhouse. he has some pictures of a couple cranks he worked on in his thread, he does quality work.
i guess i should clarify, the mt-12 was in a ntc3 not a 235. up to this point i haven't chimed in about putting a 5 port 12 in a 235 but i am almost positive those motors won't have the torque to push that car around the track. no matter how you gear it.
