Old 01-15-2013, 06:17 PM   #1
Default nitro help
i installed a super charger on my 4.6 its great but rounded the spur i am puttin a steel 48 tooth spur what bell shoul i run
savageintegy is offline   Reply With Quote
Old 01-16-2013, 01:26 AM   #2
blis's Avatar
The odds are that you didnt mesh it too well hence why you stripped it. And to be honest I'd stick with plastic spurs otherwise something else in the transmission will have to give way if things go wrong.
If you lengthen the gears you will put more load on your transmission systems so assuming you have more RPM now, it's best to drop the gear ratio and let the engine open up so to speak.
You can go here -> http://capricornrc.com.au/home-2/lab...ed-calculator/ for a speed and gearing calculator, just use first gear if you are single speed and change the values to suit your car and you should be able to find a happy place for the car's transmission.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
looking for some nitro help vypr2002 Nitro Off-Road 20 07-26-2010 09:08 PM
rc nitro help mrblonde Georgia Racing 10 02-06-2010 08:12 AM
Electric Guy goes Nitro...help! eziduzit Electric Off-Road 13 05-18-2007 08:40 PM
Frustrated with my first nitro, help! bcmorrison Rookie Zone 6 02-21-2005 10:49 PM
Changing from 20% nitro to 16% nitro, help please. Tabushi Nitro On-Road 9 11-27-2003 09:50 AM
SEO by vBSEO 3.5.0
