Neo Attack 235mm Road Car
#76
Attack
Hey dude,
Seriously you should run the car in its out of the box form to see how it goes before laying down servos,lifting fuel tank ,changing battery positions etc.
This car is very stable with its current set up,and also well balanced,dont change it.
Learn how the car goes and then make one change at a time to see the effect[better or worse] rather than a series of changes.
Then you can learn what helps and what doesnt.
Just my 2 cents
Just my 2 cents
#77
Re: Attack
Originally posted by opposite lock
Hey dude,
Just my 2 cents
Hey dude,
Just my 2 cents
#78
To REVZALOT
Let me offer the following:
1) Polish all the pivot balls
2) Polish all of the shock shafts
3) Polish the main shaft for the 2 speed
4) Polish all of the hinge pins
5) Don't be afraid to get a reamer that I think is .126 and go after the missalignment of the upper left rear hinge pin mounting holes.
6) I didn't use the adjustable pistons in the shocks, just the two hole and three hole pistions. I had no shock trouble.
If you already planned on doing this, great. I don't want you to think I am talking down to you. But I did learn that the 2 speed shaft works better in the bearings and the shifting is more consistent when that shaft is polished. Good luck and good racing with you NEO Attack.
#79
Originally posted by davidl
To REVZALOT
To REVZALOT
Do you guys run with or without the metal balls in the clutch flyweights?
#80
For under the tank batteries you can use Ofnas Brick pacs. I assemble my own, and made a bat. tray. They fit a little snug under the tank, but it works. As far as the steering goes, I can help you with that, I made my own crank. But you can provably use one off of a Mugen, with the saver included. ALl you would need to add to that is a piece of aluminum that covers the front cut out under the belt to mount the saver onto. You also need to cut a slot for the servo arm, and the servo is also angled.
#84
very good mod..any other mods you've made?any pics?
#86
special carbon chassis...........
