Drift cars
#16
Drift
Not aware of any drift package for V1S.
You could try using the drift tires, but from what I understand, with HPI, the Stage D shifts the weight of the car forward and towards the center to achieve a better balance.
I'll do some testing to see how different this set up would be compared to just using drift tires with a regular car, then I'll post my findings.
As for servos, maybe it ought to be a fast enough servo, then again it might not matter so much.
#17
wat makes the stage D package shift the weightS???
#18
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
drift competition
How's this drift competion works? I mean what's the rules? Is this goin to be like the grip racing?
Or is it goin to be like the real drift comp. That they give score how well you drift your car?
Like only two cars will be competing each other?or more?
#19
what should I do to make my grip car to be a drift car?
Can I make my FW05RR shaftdriven to be a drift car?
What should I change?
What modification should I do?
What settings?
What kind of tires?
Any opinoin is welcome. Thanx.
What settings?
What kind of tires?
#21
Originally posted by GReddy
yes just like any other 1/10 on road car nitro or electric
just use tires made of abs plastic pipe
if you goto drift forums you will see that everyone uses them if you think i am crazy
I can get them easy.
Which is better tires to use?
Should I locked my diff? Front and rear?
I need the basic drift settings.
#24
Originally posted by Thai3g_Eclipse
I was thinking about trying this out too. But if I don't like it, how good are these Yokomo drift cars as grand tourers?
I was lookin at their cars and evrything looks the same as the touring cars,its all adjustable.
The thing is the both front and rear diff is locked,and if you try this out on grip racing,your goin to have a hard time to tune your car,but you can buy and change it to a regular diff and case to work on grip racing,I'm sure its available.
Hey Greddy! I think ill just use the yokomo drift tires,and its looks nice too!!heheheh.
#25
here check these vids out mostly all of the cars are NOT the yoke drifters and are just cars using PVC tires and a stock silver can motor
http://www.frequency-rc.com/movies/SGDrifters4.mpg
http://www.frequency-rc.com/drift/sg3rd.mpg
then agian they are electric
SG Drifters!
SG Drifters!
#26
the PVC tires is it made by attaching the ring of PVC to the rims??
#28
how actually the PVC rims help the car to drift???
btw...
does the servo plays a great part??
btw...
#30
the yokomo drift tires is actually made of wat??
rubber?
rubber?
