Like Tree12Likes
Old 07-18-2017, 08:28 AM   #1261
Get rid of the yellow piston buttons. When I used them the clips were constantly deforming and coming off within the shock. Once I changed back to the stock white buttons there has not been an issue since.
Serpent 977
James73 is offline   Reply With Quote
Old 07-18-2017, 09:12 AM   #1262
You may be right, the yellow pistons are supposed to be more precise dimensionally, but they seem to be more prone to deforming. I am switching back to the white Delrin pistions......
Dan_E_RCTEC is offline   Reply With Quote
Old 07-18-2017, 12:32 PM   #1263
dan_vector's Avatar
Trader Rating: 27 (100%+)
There is nothing wrong with the yellow LF pistons. I use them and never had a clip come off. All you need to do is run the shock longer at 15mm all round. The clip will still come off in a crash with the stock pistons if you run the shock at stock lengths. The clip deforms when the shock bottoms out in a crash or when you hit a curb hard. So at stock lengths it don't matter what piston you run.
Another way to improve the shock is by lightly sanding the piston to very slightly reduce the thickness of the piston so that it freely rotates on the shaft with the clips fitted. Just use some fine emery paper and about 30 seconds of circular sanding and jobs done. This goes for the stock and LF pistons. If you have the LF pistons continue with them as they do make for a smoother shock but just sand them slightly so that the rotate that's all.
Once built 'properly' using the tips above these are hands down the best shocks we've had from Serpent. Very easy to bleed and get repeatable rebound. I really like the shocks over the previous RCM shocks heck the nut used to come undone on those which was also a PITA.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-03-2017, 09:09 AM   #1264
RC MARKET's Avatar
Serpent 977 Flow Bumper
James73 likes this.
RC MARKET is offline   Reply With Quote
Old 08-10-2017, 08:33 AM   #1265
rcfiend's Avatar
Trader Rating: 29 (100%+)
I'm looking for a tool to round the edges of my tires after I true them down. I was thinking of just going to home depot and getting some sand paper and gluing it to a paint stick. Anyone using something else that I can purchase?
rcfiend is offline   Reply With Quote
Old 08-10-2017, 08:35 AM   #1266
dan_vector's Avatar
I use a tile file. Like this....
QEP Diamond Grit Porcelain Tile File-10586Q - The Home Depot
TeamCarnage and snuvet75 like this.
Old 08-10-2017, 09:25 AM   #1267
TeamCarnage's Avatar
Trader Rating: 22 (100%+)
Gravity Pro Shop Team Gravity Rc | RC Racing
Another option. Dan's tool is half the price.
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 08-10-2017, 10:48 AM   #1268
rcfiend's Avatar
Originally Posted by dan_vector View Post
Thanks Dan!
Old 08-10-2017, 10:49 AM   #1269
rcfiend's Avatar
Smile
Thanks. I saw that one on ebay, that's where I got the idea of doing sandpaper on a stick.
Old 08-10-2017, 11:34 AM   #1270
dan_vector's Avatar
I've had my tile file for what must be 10 years! Still going strong!
shiston and TeamCarnage like this.
Old 08-21-2017, 12:19 PM   #1271
on the new flow bumper can someone conferm which insert is the fully closed
and which is the half open. the insert that is closed at the bottom is half open
at the top and the insert that is closed on top is half open on the bottom.so
not sure which is for low speed steering and which is for high speed steering.
thanks rick..
rick oxley is offline   Reply With Quote
Old 08-21-2017, 12:54 PM   #1272
dan_vector's Avatar
thanks rick..
If you go here the explanation and configuration is self explanatory. Hope it helps.
Serpent Model Racing Cars - Product - Bumper 1/8 FLOW
Old 08-24-2017, 04:09 AM   #1273
Stusdal's Avatar
Looking to replace the pins in my driveshafts. Can anyone help me with sizes or partnumer?
Dont have my car here so cant measure my self.
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 08-24-2017, 11:18 AM   #1274
dan_vector's Avatar
3x12
Old 09-29-2017, 05:20 AM   #1275
Stusdal's Avatar
Is it common to use the hard suspesion parts, 903610, 903611 etc?
I dont see it mentioned in many setupsheets - but from previous classes/cars this is sometimes parts they "always" use anyway.
Is it the same here or is standard the more common way?
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
