Serpent 977 Viper
#962
Hey guys,
Back into 1/8th after a 16 year absence (last race was mendip with a serpent 6000 sprint!) and now back building a viper 35th Anniversary edition. How things have changed, crazy beautiful bit of kit. Quick question, thread lock. It's a lot of bolts into aluminium, does anyone use a little thread lock to keep all the bits hanging together, or does this make pulling the thing apart a 'mare.
Started the build, no thread lock so far, so interested in options!
#964
Hey guys,
#965
+1 definitely not on the chassis screws! There is only very few places need locktite on the car to be honest. Just the smaller screws that are Alu to Alu and perhaps the set screws on the 2sp shaft pulley. The only screw I've had come loose on the car was the 2sp shaft pulley never had an issue elsewhere on the car. Welcome back!! I'm local to Mendip so I'm sure I'll see you around.
#966
No to locktite
Hey guys,
I use very little locktite. Only on the steering linkage and where there is and plastic to steel. Re: servo saver and throttle linkage. Also on the shock shafts to hold the Pistons on. Get yourself a good 2mm and 2.5mm. And you'll be in good shape. Locktite will give you many headaches. You will be slotting stuck screws with the Dremel cutoff wheel and using a flat head to remove them.
I do belive the instructions have the recommended spots to use locktite with a small blue drop to indicate use
Welcome back !! Enjoy the build
Don
#967
The only thing that have come loose for me is the rear camber link, where its mounted on the carbon tower. A drop of loctite solved the problem.
#968
locktite can be a pain in the .... when trying to loosen the screw. I tip can be to heat the screw wich will softhen the blue locktite.
Hope this helps. Have fun
#969
Sorry to hijack the convo,
I have some credit with a hobby shop so i will be converting my 977WC to a 977EVO,
I have the ffg parts to complete the conversion:
SER903623 - Serpent Aluminum Lower Flex Mount
SER903624 - Serpent Carbon Lower Chassis Brace
SER903625 - Serpent Carbon Tank Fix Plate
SER903622 - Serpent Top Flex Mount
SER903621 - Serpent Carbon Radioplate
SER903620 - Serpent 5mm Aluminum 977 EVO Chassis
SER903379 - Serpent Areo Bumper
anything missing?
anything missing?
#970
anything missing?
anything missing?
#971
don't really need the SL8 XLI,I'm happy with my current gearbox for now,till i see the need i would be really happy to spend 80bucks on a XLI.
for now i just want to upgrade the chassis.
#972
anything missing?
anything missing?
#973
the radio tray(radioplate) is one solid piece,SER903621 - Serpent Carbon Radioplate
there is no more split radio tray.
#974
