Serpent 977 Viper
#901
if you mean.. what you need to do before starting the day.. checking your settings are right and adjusting as you go on the controller.. when after practice days and race days especially stripping down the engine down.. and using afterrun oil.. or oil from automatic gear box.. the red stuff, fresh.. as has been mentioned in other threads.. to prevent rust on the crank shaft and bearings..
oil the one way bearing in the 2 speed transmission from time to time.. and the thrust bearing on the clutch as well.. before each race or practice day.. and more often on race day.. check it..
#902
#903
Just to add make sure you use proper one way bearing oil for the one way bearing. Any oil just won't do. Use proper thrust bearing black grease on the clutch thrust bearing as well as high temperature bearing lube on the clutch bearings. It is important to use the right greases and oils for the particular application.
#904
Are all the belts replaceable with the MRX-5 rubber belts or are you guys using other brands to?
#905
Personally I don't have an issue with the stock serpent belts. It is important to regularly clean the pulleys regardless of the brand of belt you are using.
#906
In know (now).
Nobody's thats doing something with the belts (treat with certain products?)
#907
im not sure what you mean Claude , you asking if anyone is useing something to treat the belts... , other wise as said.. you can clean the belts with pressure gun that is used at many race tracks.. when not racing.. so..
#908
Some people soak belts in WD40 for 24hrs but that's mainly to soften them up. I do that on my electric TC but I never bother on my gas cars. Stock belts and pullys are fine. Just keep em clean if you are running on a dirty track.
#910
Ok thanx
A good cleaning after every race day will make a lot off difference.
The pressure gun isn't sufficient for cleaning the pulley, you have to take it off and cleaned properly.
Makes aluminum pulley's a difference in maintenance ?
#912
Hello friends, how many degrees of turn you go in your car?
In the tool Hudy set up, it comes marked up to 30 degrees, but maybe the car works better with fewer degrees...
Thanks.
Thanks.
#913
With maximum trow (without bounding the steering servo) you can use dual steering to subtract steering angle to both directions at the same time. You can adjust this to make the car turn more or less. Look at the settings on you're radio.
#914
Thank you Claude, I know it but I would like to know it is the maximum allowed turn in order that the car works correctly. In the serpent setup a lot of information appears, but it does not indicate this information. In my opinion it is very important because if we fit an excessive turn, the car will not behave correctly, for this motive I would like to know where the limit is in order that the car turns the maximum thing without managing to be harmful... In other scales the maximum draft adjusts to 20-22 degrees, but in this scale it seems to me to be very small.
Thanks.
Thanks.
#915
