Like Tree11Likes
Old 11-18-2014, 08:18 AM   #766
Originally Posted by emancipation007 View Post
Anybody use this starter box if not which one do you use
http://www.amazon.com/gp/product/B00...=A2HUFQYBB8LM3
Take a peek at the Xceed box - wheel is small enough to provide good contact with the flywheel through the fairly small opening in the chassis plate - used one for two seasons and my only complaint is the friction wheel material is a little soft so it needs replacing periodically.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 11-18-2014, 08:44 AM   #767
dan_vector's Avatar
Trader Rating: 27 (100%+)
I too use the Xceed box (I had the mugen purple box previously which was good too). Personally haven't found the wheel overly soft or wear out quickly at all. 2 seasons on mine and on original wheel. Pre-warming your engine goes along way in making the start kinder to the box.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 11-18-2014, 09:53 AM   #768
lil-bump's Avatar
Trader Rating: 83 (100%+)
+1
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-16-2014, 10:18 PM   #769
emancipation007's Avatar
Default screw chart
I bought my 977 from absolute hobbies this past week .I recieved it and there was no screw chart in the kit .Usally kits come with screw charts and are used to measure each screw to make sure you are using the right screw .Is this an error on serpent part or is this normal.
On road and offroad man I love racing
emancipation007 is offline   Reply With Quote
Old 12-16-2014, 11:23 PM   #770
Spillertwo's Avatar
The kit doesn't have a screw chart normally. I just use a measuring tool to make sure i use the right screw
Spillertwo is offline   Reply With Quote
Old 12-17-2014, 01:59 AM   #771
Old 03-04-2015, 10:37 AM   #772
I just started racing 1/8 scale at the end of last season and was wondering what is the smallest tire size you would go for qualifying? Thanks in advance
quinnfrazier is offline   Reply With Quote
Old 03-04-2015, 11:23 AM   #773
snuvet75's Avatar
Trader Rating: 14 (94%+)
Originally Posted by lagcisco View Post
I noticed the manual shows that the steering servo arm should be at a slight angle towards the front of the car, wouldn't this cause steering geometry to unbalanced speed/torque between right and left?
Everything is at 90 degrees except the steering servo arm.. I've seen other cars that had slight angles on the steering servo arms but that angle would match the angle the arm connected to, which on the 977, doesn't seem to be the case. Am I making a big deal out of nothing? just adjust my epas, subtrim and be done with it?
I was just going through this thread and found this. I know it's late response but just wanted to give my thought since I wondered the same.
IMO it's because of the arm hitting the tank if you make the center perpendicular to the chassis. So by making the center face a bit forward, you'd have enough EPA to both directions.
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 03-05-2015, 01:12 AM   #774
M7H
M7H's Avatar
Nope.
I will try to explain.
In order to have the same steering characteristics left and right, it is important that in the centre position the servo lever is in a 90 degree angle with the steering linkage.
Just take a look at the car and you will see that this can only be achieved with the servo lever angled forward.
The servo lever travels in a circular movement, and if you just imagine the path the lever travels, you should be able to understand why the lever is under an angle.
Ehh, Dan already explained......
Originally Posted by dan_vector View Post
It's more simple than that!! The servo horn is not 90 degrees to the servo but it is 90 degrees to the servo saver arm. It's as designed and as far as I know the same on all similar designs on the market.
Serpent
M7H is offline   Reply With Quote
Old 03-05-2015, 08:36 AM   #775
snuvet75's Avatar
Originally Posted by M7H View Post
Nope.
Yeah you're right. I looked at the car and it makes sense. Thanks.
Old 04-06-2015, 02:30 PM   #776
I bought a 977 and I've 2 questions and I hope someone can help me.
1) In the Instruction manual is not written the preload of the Servo saver spring
Instructions manual: step 31/32. Strange that Serpent forgot the specify the spring preload...
2) I downloaded the shock spring chart. Serpent use the LB and not mm as other brand. I always used the mm and know I'm pretty confused.
Do you know the mm of each spring? p.e. Mugen basically have White spring 1.9mm
Thanks in advance for your help
snakess is offline   Reply With Quote
Old 04-06-2015, 06:08 PM   #777
nitrodude's Avatar
Pre load is driver preference.
Just buy the Serpent springs and you wont have a problem. The size of the wire doesnt matter, just get the springs you need. If you need softer than the kit, get softer and if you need harder get harder.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-06-2015, 06:38 PM   #778
avs
avs's Avatar
the serpent website has a little more info on:
http://www.serpent.com/product/160330/
the lb rating is a stiffness in lbs/inch. this is a more useful specification than just the wire diameter that Mugen provides. (they have more than 1 spring set in 1.9mm thick wire, as more coils reduces the spring rate).
spring rate for a coil spring: http://www.bluecoilspring.com/rate.htm )
K ( lbs/inch) = G*d^4/(8*N*D^3)
where:
G = 12E+6 (modulus of rigidity, 12 million psi for steel)
d is the wire diameter (mugen's 1.9mm or 0.0748")
N is number of coils
D is spring coil diameter (outside diameter of coil minus 1 wire diameter)
for mugen whites, I get about 15.2mm mean diameter, and 4,5 coils for the front, rear. this works out to roughly 56. and 45. lbs/inch.
Tony Shimko
avs is offline   Reply With Quote
Old 04-07-2015, 05:11 AM   #779
British Menace's Avatar
You shouldn't really go by coil wire diameter when deciding if one spring is stronger or weaker then another.
Some company's do that as a way of trying to keep you to their brand of springs.
As has been said a Mugan 1.9mm spring could have a totally different spring strength then say Kyosho 1.9mm (Just an example.)
Using lb/inch is a great deal easier and flexible to use although I would still check each spring on a tester if you have access to one.
Regards
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 04-07-2015, 10:30 AM   #780
What about the servo saver spring? Every brand specify how much is the preload of the servo saver spring. Preload is preference... ok, but Serpent must to specify a basic measure or not?
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
