Like Tree12Likes
Old 08-21-2014, 05:20 AM   #706
Flygio's Avatar
Originally Posted by dan_vector View Post
Doesn't make much sense to me. What is the difference in l/r weight that your seeing? Sanwa BLS are low profile servos with only 7kg torque I can't personally believe that you get enough brakes or steering hold performance with those servos! I'm using standard size servos and I'm in balance.
Sorry srg-bz standard size servos! The bls are those I want to install.
Flygio is offline   Reply With Quote
Old 08-21-2014, 10:33 AM   #707
dan_vector's Avatar
Trader Rating: 27 (100%+)
Honestly don't. You'll regret the loss of power going from the BZ's. Have you tried putting the car on scales on all 4 wheels? What's the readings?
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-21-2014, 12:20 PM   #708
cosmokitten's Avatar
Low profiles are no where near powerful enough for an 1/8th Onroad car in my opinion. Most only have around 6-9 kg holding torque which won't cut it. Low profiles are designed for light electric touring cars. If you want to save weight on the electronics then go for titanium geared standard size servos. My 977 is pretty balanced L/R running Sanwa ERS-962 servos and a xceed rx lipo.
Any thoughts on the Ko Propo BSX2 low profile line? They have up to 18kg of holding torque and are only 48grams...
I would tend to think that this would be an interesting option for those wanting to shave some weight.
Thoughts?
cosmokitten is offline   Reply With Quote
Old 08-21-2014, 01:06 PM   #709
dan_vector's Avatar
I'd still be dubious. Your putting an awful lot of stress on a servo that was ultimately designed for an electric touring car! I'll be sticking with servo's designed for the job in standard size but hey you guys can do what you want to experiment but its a heck of an investment if it doesn't work. At that torque I would consider using one on the throttle/brake but certainly not steering.
Old 08-22-2014, 01:18 PM   #710
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
To be honest, your gonna have a very hard time getting perfect chassis balance L/R. Balance will ultimatly be achived by adjusting the preload on the shock collars. Always chose your servos based on application, not weight. At the end of the day, those few grams are not going to keep you out of the winner's circle.
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 08-22-2014, 05:34 PM   #711
Anyone know if you can use the same starter box mounts/guides for the 748 and 977?
Just ordered both cars but don't really want to buy/carry two lots of starter boxes if I run both cars on the same day.
Also, are the springs between both cars the same?
implusepro is offline   Reply With Quote
Old 08-23-2014, 02:00 AM   #712
dan_vector's Avatar
No you'll need to adjust the starter box each time you change cars. It's not really that difficult once you know what the change is.
The front springs are 23mm long on the 977 which is the same as the 748 front and rear. The 977 has 27mm rear springs but you can use 23mm springs on the rear as well. You'll usually run softer springs on the 748 than the 977.
Old 08-28-2014, 11:12 AM   #713
Evo 13's Avatar
If anyone is interested, I got a bulk sale of (21 new pairs) of 1/8 foams: See the sales thread for details.
21 PAIRS OF "NEW" 1/8 KYOSHO REDBOX FOAM TIRES
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 09-01-2014, 03:28 AM   #714
Bishop's Avatar
Finally got to run mine on Saturday, loved it to bits, such a good car, most everything on it is flawless, two speed and clutch never drifted on me once set, was so composed to drive in general.
To be fair I was not pushing it to any limit, new scale to me, entry level Nova Brave, and I ran 16%, but overall the package worked great for my first time out in 8th scale.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-01-2014, 07:06 AM   #715
dan_vector's Avatar
There is nothing like a 1/8th nitro car at full chat!!!
Old 09-01-2014, 07:14 AM   #716
Bishop's Avatar
There certainly has an epic quality about them, and Serpent created a damn good bit of gear with the Viper, mine is used and has some miles on it, but nothing on it seemed to wear to the point you'd notice within a single meet.
Bugger me though if they don't half chew through tyres fast though.
QRCCRA
www.qrccra.org.au
Old 09-01-2014, 08:49 AM   #717
dan_vector's Avatar
Depends a lot on the track surface and the shore of tyre used. Throttle control contributes a lot too as an 1/8th car can wheel spin significantly if your a bit of a throttle jammer
Old 09-04-2014, 01:32 PM   #718
gearhead_22's Avatar
Send a message via AIM to gearhead_22
my 977 is very good on tire ware at my local track. and goes through tires fast at another track that I race at. so track surface plays a big role on tire ware.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 09-05-2014, 03:45 AM   #719
Bishop's Avatar
Yeah our track can be fairly high tyre wear right now, it was fine though, I knew going into 8th scale tyre wear was going to be higher than 200mm, or my electric (which also runs foams).
For the 20min final I ran some 37s all around, it was good to drive, and I was getting easier on the throttle by the end of the day/night, so there was enough left on the rims to probably run a qual heat next meeting on them.
I'm saving money on fuel though, 16% through a Nova Brave, two fuel stops in the 20min final, I was getting 7+mins run time.
(I'll be trying the 9mm insert I think based off that)
QRCCRA
www.qrccra.org.au
Old 09-07-2014, 03:50 AM   #720
JamesHealey's Avatar
Tyre wear should be lower in 8th compared to 10th, the down force in 8th means the car should look after the tyres more.
32/35 shore tyres on a 200mm wouldn't last where as they do on 8th no problem.
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
