Old 08-06-2014, 05:29 AM   #691
Send a message via ICQ to CivicTuning
Hi everyone !
I hope this hasn't been asked yes, but what do you think of the carbon chassis voor the 977 ?
Is it worth it ?
http://www.redrc.net/2014/08/serpent...e-chassis-set/
Thanks !
Greetz,
Christoph
Capricorn LAB-C801
RB CX-R
Futaba 4PK
CivicTuning is offline   Reply With Quote
Old 08-06-2014, 06:01 AM   #692
Trader Rating: 22 (100%+)
Yeah there is a little 'extras' bag in the kit which has a couple screws etc and an extra ball cup is in there. Can't remember what main bag it's in though - might be the radio tray parts bag I think.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-06-2014, 07:11 AM   #693
MantisWorx's Avatar
Trader Rating: 27 (97%+)
Originally Posted by CivicTuning View Post
Hi everyone !
Is it worth it ?
Thanks !
Greetz,
Christoph
OH MY
MantisWorx is offline   Reply With Quote
Old 08-06-2014, 12:40 PM   #694
Originally Posted by MantisWorx View Post
HUH? the pcs i made replace the shocks so if anything is damaged then the shocks setting will be off anyway and that included chassis balancing. they simply replace the shocks and do not connect to the chassis except for on the shock tower. if you set your droop on a tweaked chassis on the arms it will be worse than if you set it with my balancer because the further you go away from the centerline the worse the tweak will be . Maybe you didnt look at the pic closely, they do not touch the body mount, that wouldnt make any sense?? BTW it doesnt matter where you set the droop as long as its the same point on both sides. .7mm really isnt that much especially considering the tires change in a race from 3-5mm, which in effect changes your droop settings, ever scale your car after a race? If what you say is true then why bother measuring shock lengths? You cant tell me that sliding a piece of metal under a flexible arm and "eyeballing it" is more accurate than a true measurement from center to center. thats like saying a slide rule is more accurate than a pair of Mitutoyo calipers!!
Great Thanks. I didn't know who I was speaking with!!
rangulo is offline   Reply With Quote
Old 08-06-2014, 07:18 PM   #695
jkviper's Avatar
well, looked but no tie rod ends in kit.
was hoping maybe another manufacturer uses the same type parts that are orderable.
just ordered some Associated Servo Link Rod ends, look similar so hopefully they will fit. will post the outcome.
jkviper is offline   Reply With Quote
Old 08-08-2014, 03:15 AM   #696
RC MARKET's Avatar
Serpent New Product
RC MARKET is offline   Reply With Quote
Old 08-08-2014, 02:02 PM   #697
Bishop's Avatar
Got to say, that option chassis is the most expensive option I have ever seen, looks epic though...
And, I spent some of today fitting servos and receiver etc on my recently acquired 977, it's really nicely designed, Mugen I think set a standard with receiver box design etc, but the Serpent has gone so much further now with the layout, the radio box design and servo wire running is fantastic.
Only thing I'm still working out is how to run the battery wire across, got to make up some custom cables for the battery, and plug into the radio box.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-08-2014, 07:37 PM   #698
OH MY
Almost here.
desotoracing is offline   Reply With Quote
Old 08-12-2014, 01:47 PM   #699
jkviper's Avatar
Originally Posted by snuvet75 View Post
966 camber link ball joints work. They are a bit bigger on outer diameter so if u want to put that on inner side of steering link u would have to grind it a bit but it fits well.
Thanks, appreciate the feedback. Looks like the serpent part numbers are back in stock so just ordered some.
Old 08-12-2014, 02:47 PM   #700
By the time I received my 977 Paulie B had the wire deal figured out - running it along the radio box and over the tank in the gap at the front - just chamfer the bottom corners of the tray so it will not cut the wires , have not had any issues with this path.
Empire Racing - Serpent - K.O. Propo Electronics - Tornado Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 08-12-2014, 10:50 PM   #701
Serpent has a tech tip on their website to help with the wiring. It can be found here http://www.serpent.com/news/13657/Te...tery-lead.html
I've personally found that only Airtronics/Sanwa plugs fit properly in the 977's battery connection retainer.
Old 08-20-2014, 02:14 PM   #702
Flygio's Avatar
Hi guys. Did you ever check the weight bias of the Viper left to right? Seems to have quite a difference, with the muffler side more heavy...
I wanted to install new electronics, going to low profile servos to save some grams, but I'm now thinking things could get worse
Flygio is offline   Reply With Quote
Old 08-20-2014, 02:53 PM   #703
Low profiles are no where near powerful enough for an 1/8th Onroad car in my opinion. Most only have around 6-9 kg holding torque which won't cut it. Low profiles are designed for light electric touring cars. If you want to save weight on the electronics then go for titanium geared standard size servos. My 977 is pretty balanced L/R running Sanwa ERS-962 servos and a xceed rx lipo.
Old 08-21-2014, 03:10 AM   #704
Flygio's Avatar
I run sanwa bls and LiFe, still a lot more weight on the left side...
Old 08-21-2014, 05:15 AM   #705
Doesn't make much sense to me. What is the difference in l/r weight that your seeing? Sanwa BLS are low profile servos with only 7kg torque I can't personally believe that you get enough brakes or steering hold performance with those servos! I'm using standard size servos and I'm in balance.
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 01:09 PM
SEO by vBSEO 3.5.0
