Serpent 977 Viper
#661
977 Viper WC Rear Drive Shafts (dogbones)
Finished with my 977 WC assembly and I noticed that the rear drive shafts do NOT sit deep into the rear solid axle. Here is the pic. Following the assembly instructions, the dogbones are sitting at the very tip. How do I shim them in?
#663
#664
Suspended
Location: im from cali but lived in texas most of my life
THE SERPENT 977 VIPER WC
i finally got a chance to race test,my serpent 977 viper and it was amazing and was extremely easy to drive ! Im looking foward to do some more testing this month and hope to be prepared for the texas regionals in October
#665
hi everybody,
i have a question regarding the set up sheet.
I don't know what is the Connector Type (none, rubber, alu)
Could someone help me please ?
Jeff
Jeff
#666
It's referring to the stiffener between the rear bearing blocks and the 2 speed shaft bearing brackets. You have a choice between full stiff (alu) half stiff (rubber) not stiff (no connector). You have to buy the connectors as they don't come with the kit. Well not in my kit (pre-wc).
#667
Yes !
Thanks.
For the alu, the ref is 903357. It's the original one.
Thanks.
#669
#670
I also had a great weekend with the car at the SWCS event. TQ'd first and second round and was on a 18lap run in the third but ran out of gas, had fast lap of the day on saturday. track temps were 148 degrees!!! even though i had the exact same setup as i had when i won the BIGGIE last month it was a bit of a handfull. i played with the rear camber link, lowered the roll center and didnt like that so i went up.5mm from stock moved caster back 2mm, and increased rear droop by 1/4 turn and got the balance back! results were almost 1/2 second quicker than the winner ( had a rookie pit guy) so in a nutshell i got flipped backwards on the start, had to pit for a retune and ran out of gas! still managed to reel myself back up to second place. my 20lap avg was FAST! I gotta say the TOP engine was FANTASTIC!! highest top speed and monster infield power. Came off at 217
#671
sorry posting from am ipad and con only post one pic per post
#672
one more!
#673
Did u ran the body without a wing
#674
yes, this body does not come with a Gurney flap
Not sure how many of you are into Formula one but look at the trailing edge of the maclarens rear main element! its supposed to increase rear downforce without the extra drag. i will machine one out of carbon before my next outing.
#675
Wings or gurneys made out of anything other than lexan are banned. At least here in the UK anyway....
