Old 07-04-2014, 06:57 PM   #646
cosmokitten's Avatar
Originally Posted by tl2111 View Post
If you can get a shallower spring cup(Kyosho) it can achieve 6mm ride height on 74mm tyres with long spring and ball joint.
Kyosho's spring cups are shallower than the serpents?
cosmokitten is offline   Reply With Quote
Old 07-05-2014, 07:46 AM   #647
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
yes, Kyosho older type spring cup is shallower
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 07-06-2014, 08:28 AM   #648
Originally Posted by dan_vector View Post
Thats a good point. I also have an xceed 1300Mah lipo pack in my old 966TE. Its bound to be lighter than the protek pack....
Dan_vector,
Ever verify / test the actual capacity of your Xceed lipo?
Thanks!
Old 07-06-2014, 11:24 AM   #649
Trader Rating: 22 (100%+)
Dan_vector,
Thanks!
No never tested per se but I can tell you that I put in over 1000mah after running a 45 minute a-main and the voltage is still over 3.8v per cell. My guess is that it would be more than 1300mah.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 07-06-2014, 12:14 PM   #650
Sweet,
Truly an interesting option since it only weighs 60 grams.
Thanks!
Old 07-06-2014, 10:22 PM   #651
Originally Posted by Fly'n Fish View Post
Using a steel bell. No seized bearings as far as I can tell. I think if you somehow seized the bearing it would make such a racket and your car would be creeping like mad, I dont think anyone (ie the previous owner) could have missed it but you never know. Anyone have a brand new bell just fitted that can report on 'wobble'?? thank you
Yes, I had a brand new steel bell that wobbled on a new car. Changed it out with another new one and wobble solved.
Not too sure whether the bell was warped from factory, or whether I warped it myself by tightening the gears on too tight? In any case, that wobble did not look healthy for the gears.
Old 07-09-2014, 11:05 PM   #652
bcebwecb's Avatar
Clutch bells are hit and miss. If you have a bad one, I recommend that you just throw it away and put on a new one. There's no use in messing with a bad clutch bell.
Brandon Cho
________________________________________
Team ARC USA - Hobby Authority Distribution - Prolevelrc - Hobby People
bcebwecb is offline   Reply With Quote
Old 07-10-2014, 08:25 AM   #653
any results from the back-to-back testing? Which is preferred, using the shorter ball joints in the rear or using the shorter springs?
Awaiting what you've learnt...
Have gone with the shorter 23mm springs (I have pinks fitted) and the long ball joints , all seems fine and no detrimental effects on handling by using the shorter springs.
See below
This below is how it was originally with long red springs
8thracer is offline   Reply With Quote
Old 07-10-2014, 01:16 PM   #654
Trader Rating: 14 (94%+)
Just a quick question to you guys,
The 2nd picture above, you see he put the tire rim stickers inside the tires. Other than it making it look good and preventing chunking, does it serve any other purpose? I don't do that because I'm afraid, as the tires wear out, the sticker starts touching the track floor and causes loose traction. Maybe the outer diameter of the sticker basically tells us when to stop using the tires (I have never measured the diameter of the outer rim of the sticker though)? But that only applies when you put the sticker perfectly in the middle, which I don't think is possible. What do you think?
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Old 07-10-2014, 11:26 PM   #655
The sticker should go on the outside edge of the tyre? I don't use the stickers anyway as they don't do anything to protect the tyre or lessen the chances of chunking. In my experience anyway...
Old 07-11-2014, 01:32 PM   #656
Yeah I think it should go outside anyway too..
Capricorn LAB C03
Old 07-14-2014, 07:06 PM   #657
See below
Appreciate the info, thanks!
Old 07-14-2014, 07:09 PM   #658
Default RX protection?
Gentlemen,
Does one need to protect the RX within the 977 Rx box from vibration? In other words, does one need to add foam or something to dampen vibration?
I can't see there being much room to do this, hopefully, it's not needed.
Any experience is welcomed!
Thanks!
Old 07-15-2014, 04:44 AM   #659
Flygio's Avatar
There is no need to do that, if your receiver is very small maybe you can double-side tape it inside the box.
Flygio is offline   Reply With Quote
Old 07-15-2014, 07:19 AM   #660
The Rx shouldn't be taped into the box. There is enough dampening occurring naturally from the servo wires etc around the Rx. If you tape the Rx to the box then you are providing a vibration transferring pathway! There is no need to foam protect the Rx either.
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 01:09 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
