Like Tree2Likes
Old 06-02-2014, 09:35 AM   #586
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Marcus are you running CVD's in the rear or dog bones?
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 06-08-2014, 10:37 AM   #587
cosmokitten's Avatar
Default SRG-BLS servos
out of curiosity, anyone using Sanwa SRG-BLS servos for both throttle and steering in the 977?
Wondering whether these servos would be "man" enough for the job.
Would you guys recommend it?
Thanks!
cosmokitten is offline   Reply With Quote
Old 06-08-2014, 04:00 PM   #588
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by P2gee View Post
Marcus,
Its been a while, but I was experiencing the same type of tire wear when I was running the 966 at RCRCNT. I think I played with the length and mounting location of the rear upper suspension link and got the tires to do the accepted cone on both tires. I have to admit though, your car looked plenty "acceptable" to me during the main regardless of how the rear tires looked at the end.
Steve McLaughlin
Thanks, i look forward to the next one!
Its a WC so it has CVD's
MantisWorx is offline   Reply With Quote
Old 06-08-2014, 11:39 PM   #589
Trader Rating: 23 (100%+)
Thanks!
No those servos are designed for 1/10th 190mm TC. They are only 7kg torque so no where near strong enough for a 1/8th scale car - no low profile servo would be suitable. If your a sanwa fan (as I am) then look at the ERS-961 or 962 brilliant servos for the money.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 06-09-2014, 08:53 AM   #590
Thanks Dan_Vector!
Old 06-23-2014, 07:04 AM   #591
Default Serpent 977 Alu screw kit
Anybody using these?
If so, any thoughts? are they robust enough?
Thanks!
Old 06-25-2014, 05:20 AM   #592
Thanks!
I use the Xceed RC Titanium screw kit as titanium is stronger that aluminium however the aluminium screws are a touch lighter.
In my 411 and 747 I use the alu screw kits without any issue but prefer the titanium in my 977 as I feel more confident with the stronger hardware for the riggers of 1/8th racing. I'm sure the alu screws would probably be fine as well but personal preference in titanium.
Old 06-26-2014, 06:55 PM   #593
Thanks for the info!
Old 06-26-2014, 06:57 PM   #594
Where do you think more torque is required? on throttle/brake? or steering?
Old 06-26-2014, 07:41 PM   #595
On the steering. You need the holding power
Old 06-26-2014, 08:02 PM   #596
Interesting...
What do you recommend as min torque requirements for steering and throttle / brake for 1/8th on-road?
Old 06-26-2014, 08:09 PM   #597
I use a KO RSx response which has a great mix of speed and torque. I say anything with a minimum of 150 oz of torque
Old 06-27-2014, 01:01 AM   #598
Trader Rating: 14 (94%+)
Default 1. Aluminum clutch bell 2. clutch spring
1. Is aluminum clutch bell really hard to set up? My friend says so but I have used it before, not sure if I was lucky, I got no problem at that time. I will only use it for big races. The bell I have (I got it from my friend) has distinct threads inside the bell where the contact between the bell and the clutch shoe occurs. Is it normal? I just ordered a new bell but just curious.
2. I recently posted a thread regarding possible bogging at lower end. But it seems to me that it's coming from clutch. My friend says it's from really bad clutch. He told me to use Sheperd super hard clutch spring but I don't have it and I don't understand why it has to be that. I've been using Serpent hard spring. I tightened the preload 3.5 turns in. How do I solve this annoying problem? Last race, I ended up breaking the con rod. The bogging must have put too much load on the engine. Please advise,
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Old 06-27-2014, 01:13 AM   #599
Interesting...
Personally I use the same servos in both steering and throttle/brake. 0.09s through 60 and 25kg torque at 7.4v (HV Servos).
Old 06-27-2014, 01:20 AM   #600
1. The Alu bell wears extremely quickly if your clutch isn't setup perfectly. If you have a lot of slip then you will ruin the Alu bell in a few seconds. Your friend is partially right in that the Alu bell is quite sensitive to needing accurate clutch setup. If your not 100% happy with clutch setup then stick to the steel bells for now. The wear inside your current bell is not good and contributing to the issue you are having with bogging. Change it for a steel bell before continuing.
2. What end float and end play are you running? Make sure it's 0.6mm and 0.1mm. Below 0.6 will cause bogging. It's difficult to say how many turns in to set the adj nut because the setting varies clutch to clutch engine to engine but start with 10mm down from the end of the crankshaft and then tune it from there. You don't need a shepherd spring - there is nothing wrong with the stock spring. However it is possible that the spring has been damaged by excessive heat or is old and so changing to a new spring may help.
I doubt your broken conrod is totally attributable to a bogging clutch however you will see higher engine temps if the clutch is either bogging or slipping. My advice is to recheck your engine settings as well before continuing on a new engine as it's likely the piston/sleeve/head/main bearing is toast when the rod breaks...
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
