Like Tree7Likes
Old 04-24-2014, 08:24 PM   #526
cosmokitten's Avatar
Default No setscrews in the clutch shoes?
Just perusing through the instruction manual and noticed that step 22 does not include any information on installing the set screws for the clutch shoe halves?
Is this an omission or are we not supposed to install set screws? Can't imagine that, then one cannot adjust the gap...
Thanks!
cosmokitten is offline   Reply With Quote
Old 04-25-2014, 08:42 AM   #527
Thanks!
I installed it to min the gap between 2 speed shoe and housing.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 04-29-2014, 08:04 AM   #528
dan_vector's Avatar
Trader Rating: 25 (100%+)
Wow!
http://serpent.com/news/13750/Team:-...-Serpent-.html
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 04-29-2014, 12:32 PM   #529
Default steering linkage
Has anyone had issues with the steering linkage from the servo saver to the servo being weak? Ran the car for the first time and it popped off anytime any contact was made, not with a board, but even a flapper. The ball ends are smaller and the linkage itself pulled out once. Is there any reason you cannot use the bigger balls and ends for this application?
Dennis
dyoung is offline   Reply With Quote
Old 04-29-2014, 01:15 PM   #530
Dennis
Dennis Haven't had any issues as you describe , what servo arm are you using , when I first built mine last year I had a longer arm and it put the balls into a bind condition , changed to the 977 arm and the problem went away. You can make a little more robust link by suing two long links cut off approximately .100" each and using a long 3mm setscrew as a connector increases the threads engaged but you do lose adjustability.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 04-29-2014, 03:10 PM   #531
Trader Rating: 14 (94%+)
Dennis
It will keep coming out once it comes out. Same thing with 747. The ball end plastics are very weak. I recently put bigger ball and plastic combo (both lateral and medial sides) in my 747 and it's a lot sturdier. I think the ball is 4.5mm. in my 747, I had to grind a bit of the ball end margin to avoid contact between them and the gear diff but not sure in 977. One thing I know is that you CAN use the bigger balls and ball ends.
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 04-29-2014, 06:15 PM   #532
Default Front and Rear arm shimming
delete!
Old 04-29-2014, 06:15 PM   #533
Default Front and Rear hub shimming
delete
Old 04-30-2014, 10:24 PM   #534
Default Sanwa SRG-HV shimming?
Anybody using sanwa SRG servos? if so, what shimming (#'s 1 thru 4 for both throttle and steering) is recommended for optimal servo positioning within the radio housing?
Thanks!
Old 04-30-2014, 11:13 PM   #535
dan_vector's Avatar
Thanks!
I'm using SRG servos. Great choice
You just need the 1mm shims on the servos but if you add the rubber bushings that come with the servos you don't need any extra shims.
Hope that helps?
Old 05-01-2014, 04:21 AM   #536
Hope that helps?
Great, thanks!!
Old 05-02-2014, 07:18 PM   #537
Default Rear Balljoints
Anybody struggle with screwing in the rear balljoints to the shock shafts?
I had to bore the tip of the balljoints a little and then struggled with screwing them in straight. They are now screwed in crooked. Tried to straighten them out but then stripped the balljoint.
I guess I could run them slightly crooked, but doesn't seem right.
An y ideas on how to do this with more ease?
Appreciate!!
Old 05-02-2014, 07:39 PM   #538
Default Shock Rebound?
Anybody have any advice of preferred amount of shock rebound for US tracks?
Thanks!
Old 05-03-2014, 08:23 AM   #539
Default Vir-tus installation
Does the vir-tus require shimming behind the cone for proper gear alignment?
Also, can't seem to find the cone (P/N 6503) in the kit. Can I use the cone that comes with the engine?
Thanks guys!
Old 05-03-2014, 08:36 AM   #540
Paulie Bee's Avatar
Default Novarossi Virtus on 977
Thanks guys!
Stock Cone no shimming everything aligns perfectly. Make sure you hold out the crank shaft while sliding the cone down onto the race of the front bearing. There should be no play once you tighten-down the flywheel.
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
