Like Tree2Likes
Old 04-19-2014, 11:44 AM   #511
DRRC's Avatar
Trader Rating: 57 (98%+)
Thanks guys
Was having too much brake lowered the throw and feels better now
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 04-19-2014, 02:51 PM   #512
Originally Posted by DRRC View Post
yes sir
breaking loose at the back
Depending on droop setting and surface prep and or roughness it may help to add some droop to let the arms travel down further on weight transfer under braking.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 04-19-2014, 07:29 PM   #513
Thunderbunny's Avatar
Trader Rating: 22 (100%+)
Actually, adding rear droop will make it worse. Allowing more weight to transfer to the front of the car will make the car more unstable under braking. Less rear droop will help stabilize the car during braking, but the downside is that you will loose steering on corner entry. Which is a commodity in 1/8 onroad. As someone suggested earlier, I would loosen the brake adjusting nut, and adjust the brake EPA on your radio. Adjust it as to give the maximum amount of brake without locking the tires.
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 04-20-2014, 04:23 AM   #514
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
+1.
I like the idea of different brake disc. I will give that a try. I preferred the "feel" of brakes on older 966 version.
J.Gonzalez is offline   Reply With Quote
Old 04-20-2014, 04:34 AM   #515
Try... You will be surprised by the change of feeling and breaking sensation.
Nicoḷ Pasqualini (Italy)
Mugen Mrx5 wc- Os Engine - Matrix Tyres- MLC Fuel- Protoform
pasqua2291 is offline   Reply With Quote
Old 04-22-2014, 02:54 PM   #516
Camber bracket is different on the world's car. Anyone notice this? Why the change.
Theo49306 is offline   Reply With Quote
Old 04-22-2014, 05:14 PM   #517
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
dont know why but I do realise it has changed!
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 04-22-2014, 06:08 PM   #518
nitrodude's Avatar
I noticed it on my friends car. My guess is that it creates more rotation, just a guess
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-23-2014, 01:13 AM   #519
M7H
M7H's Avatar
The rear bracket is changed because of 2 reasons.
1: from the 2 holes in the old bracket, only the outer holes were usable, the inner hole on the brake side, would bind the upper camber link.
now the holes are above each other, to be able to change the rear roll center, and camber rise.
2: As you can see, the middle part of the bracket, is made a bit higher, this is to prevent the T-bracket of the rear body mount (#903536) to come lose in case you flip the car on it's roof.
Serpent
M7H is offline   Reply With Quote
Old 04-23-2014, 05:45 AM   #520
Originally Posted by J.Gonzalez View Post
+1.
Try playing with the spring/fuel tubing next to the adjusting nut. Fuel tubing only (softer) makes the brakes super smooth. if you put a stiff spring (from 2sp) then you can brake harder but they can become sensitive. A combo (small piece of fuel tubing plus the spring) can give you an in between feel.
desotoracing is offline   Reply With Quote
Old 04-23-2014, 07:59 AM   #521
DRRC's Avatar
I will try this set up
Can I use a Kappo GT or an Ison in this car?
Any thoughts? I assume it will be good in a tight small track which we have down here
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 04-23-2014, 08:19 AM   #522
Trader Rating: 23 (100%+)
either will fit but neither really have the right power band for 1/8th circuit. I would suggest the Novarossi Kangaroo engine if your on a budget. Still a brilliant 7 port engine at a very affordable price.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 04-23-2014, 05:47 PM   #523
nitrodude's Avatar
The Nova PTS is a very fast motor, and they can be had for a really good price right now. I'd get that.
http://www.serpentamerica.com/shop/p...&cat=80&page=1
Steven Muller
Ronin Speed Parts
Old 04-24-2014, 10:01 AM   #524
cosmokitten's Avatar
Serpent still lists the molded pinion wrench , part number 909590 , guess mine might be 10 years old and still works just fine.
Thanks for the info!
However, Can't seem to find availability anywhere for P/N 909590, + this part needs to used with 909593, which is also difficult to find.
Can anyone confirm what they are using to remove the pinions from their bells?
Can anyone confirm whether the Mugen tool will work? Tried the Kyosho ones and they don't fit.
Thanks!
cosmokitten is offline   Reply With Quote
Old 04-24-2014, 10:14 AM   #525
lil-bump's Avatar
Trader Rating: 82 (100%+)
Thanks!
I use the Mugen tool on my sedan (747) bell. Not a perfect fit but does the job. I never tried this tool on the 1/8 Serpent bell.
Hope this helps
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
