Like Tree7Likes
Old 04-15-2014, 12:27 PM   #496
zeddy's Avatar
I did not strip them. The end of the teeth was worn down more than usual for the run time i did.
zeddy is offline   Reply With Quote
Old 04-15-2014, 04:44 PM   #497
nitrodude's Avatar
Originally Posted by Serpent-Dan View Post
17 - 19mm
From the bumper?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-15-2014, 04:54 PM   #498
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Yes Steve
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 04-15-2014, 08:19 PM   #499
Phil Trotta's Avatar
Teddy it's because the track was filthy. If we were on clean surface they'd be fine. My touring car took a beating on the gears Sunday
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 04-16-2014, 05:23 AM   #500
djiewie's Avatar
If the teeth look rugged it can be a little too much play.
Adjust with a piece of paper pressed between the teeth and messure if it was indeed more. With giving the wheels a turn the spurs will turn also without much noice normally with new spurs. Check the bearing play on the clutch pressing the pinions apart from the spurs. Check the tranny axle play the same way. Check play on the plastic bearing holders, glue them if neccesary.
Maybe just little debris , stones on the track? like mentioned.
Hope it helps you, have fun.
djiewie is offline   Reply With Quote
Old 04-16-2014, 06:12 AM   #501
zeddy's Avatar
Smile
Thanks guys for the reply
Old 04-19-2014, 04:20 AM   #502
cosmokitten's Avatar
Originally Posted by supacha View Post
Hi guys,
I have some trouble with the roll bar at the radio plate.
I use the aluminum radio bracket. Now the roll bar breaks after approx 15 minutes due to high vibration.
Does anyone of you have the same problem and what can I do - appart from using the plastic bracket because it will eliminate the vibration because it is weaker.
It doesn't break because I crash.
Anyone know of a fix?
Do we need to stay away from the alu radio bracket?
Thanks!
cosmokitten is offline   Reply With Quote
Old 04-19-2014, 04:23 AM   #503
Default Recommended Tools
There doesn't seem to be a serpent specific pinion gear removal / installation tool available.
Any recommendations? perhaps the Mugen tool works?
Appreciate!
Old 04-19-2014, 08:12 AM   #504
Appreciate!
Serpent still lists the molded pinion wrench , part number 909590 , guess mine might be 10 years old and still works just fine.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 04-19-2014, 10:22 AM   #505
DRRC's Avatar
Trader Rating: 57 (98%+)
Just got a 977 what a beautiful race car
Only problem I have noticed is it spins when on brake
Any solutions?
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 04-19-2014, 10:28 AM   #506
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Any solutions?
When you say it spins are you talking about it does a donut when going into a turn or the drivetrain is still spinning even when on break?
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 04-19-2014, 10:40 AM   #507
DRRC's Avatar
yes sir
breaking loose at the back
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 04-19-2014, 10:56 AM   #508
yes sir
I would suggest you start by getting lossening up on the brake nut on the throttle lever so the car has less brakes. Right now it sounds like you have too much brakes and is a little too sensitive. If you loosen it up a little bit it will make the car a lot more controllable when braking.
Jay Williams
Xray RX8 2014
Old 04-19-2014, 11:08 AM   #509
dan_vector's Avatar
Trader Rating: 25 (100%+)
I also use a longer piece of fuel tube on the linkage to take some of the bite out of the brake. Basically it allows more servo movement before the brake locks.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 04-19-2014, 11:11 AM   #510
This is because you brake too much. I had yor same problem, and i solved changing the brake disk with mugen mrx5 one and setting again the brake. Also other italian serpent drivel (like Mazzeo, Tedeschi, Piromalli...) did this. It fits quite well, you may just look after how it fit on the solid axle, and you brake pads must measure 1.8mm (measuring steel + ferodo) or minus else the disk will not enter. No big problem anyway, and it is not very expensive
Nicoḷ Pasqualini (Italy)
Mugen Mrx5 wc- Os Engine - Matrix Tyres- MLC Fuel- Protoform
pasqua2291 is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
