Serpent 977 Viper
#376
#377
#378
Hi, I would like to know whether the bearings use in 977 same as in 966??
Thanks.
Thanks.
#379
Solution to a minor issue that maybe only bothered me
Not really a problem but an aggravation , it seemed like every time I'd take off the shift hub the dowel pin would be pointing vertical and inevitably end up on the ground , my solution was to cut a 1/2" length of fuel tubing and split it lengthwise and remove about 25% of the strip width and then insert it into the hole in the end of the layshaft so that it puts pressure on the drive pin - no more chasing that stupid 14mm dowel around the ground
#381
Hi all!
I'm having a problem with the transmission. It has happened twice now, both times I only got in around 25 laps. Kinda irritating when I live far away from the track...
The E-Clip that holds the 1st and 2nd gear pops off and the 1st gear flies off the shaft, both times under hard acceleration onto the stretch.
Does anyone know what the problem might be?
Thanks in advance.
Thanks in advance.
#383
Hi all!
Thanks in advance.
Thanks in advance.
#386
First thing I'd look at is whether you have some end play in the assembly .2mm to .3mm should work , tight here is not good ! , 2nd is there any chance that the 1st gear one way is working it's way out and creating unusual force on the clip (outside should be flush with the housing) , after checking those items you might investigate a snap ring that you apply with a tool and if you're still having issues try a new shaft.
#388
It's a bit strange, cause in my manual it says part # 110303. If I'm not wrong that is a 5 mm one...
I have ordered both 6 and 7 mm now, hopefully one of them will fit correctly.
#389
Hi all!
Thanks in advance.
Thanks in advance.
#390
#110303 is put in the 1st batch of kits, but now the car should come with #110306, which is also updated in the V2 manual.
