Old 06-25-2013, 05:48 PM   #361
blanks596's Avatar
Trader Rating: 14 (100%+)
Bumper is bent, gotta buy a new one
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 06-26-2013, 08:42 AM   #362
Racermac73's Avatar
Then it came bent lol...
TEAM SCREAM, McFACTORY, TQ WIRE, HO-B-MAX, MBR SPEED SHOP, DSI INC, SPEEDMERCHANT , 360 RACEWAY, XENON-USA.COM, TEAM SAXO, ROCHE USA, SANWA, DESOTO RACING, HOT RACE TYRES
Racermac73 is offline   Reply With Quote
Old 06-26-2013, 09:24 AM   #363
Finally get to run my car agsin this weekend!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 06-27-2013, 04:28 PM   #364
Racermac73's Avatar
Finally done..... Now stuck waiting until the weekend to go race lol
Old 07-03-2013, 09:22 PM   #365
Paulie Bee's Avatar
Originally Posted by 2CARTEAM View Post
Are you refering to the carbon wheels disk that attach to the front and rear uprights? If so yes they are worth the investment. The enhance stabilty and help to increase steering. You may want to consider a few other options that will help in the tuning of the car.
1. Alum Servo saver
2. Soft and hard anti roll bars for front and rear.
Hope this helps.
I would add SER903580 Weight bottom brass 38gr. Start with the weight all the way rear.
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 07-11-2013, 12:26 AM   #366
evirobs's Avatar
What other shock shaft can fit the 977 rear?
I am looking for shaft that are at least 2-3mm longer.
Any solution?
*************My toYs arE DriVing mE CrAzY!!*************
evirobs is offline   Reply With Quote
Old 07-11-2013, 08:09 PM   #367
2CARTEAM's Avatar
Any solution?
Try the 966 shafts.Not sure why you need longer shafts.
RC Target, Capricorn, Tesla, Ko Propo, Ulti tires.
2CARTEAM is offline   Reply With Quote
Old 07-11-2013, 09:26 PM   #368
Just ran my viper last week.
My car was understeering when im using Matrix Xtreme Rim(offest tyres).
Even I did changed the width after i have these offest tyres.
What should I in my car?I need help!
thanks
Capricorn LAB C801/OS ENGINES/FUTABA/FUTABA
victor1997621 is offline   Reply With Quote
Old 07-12-2013, 05:00 AM   #369
Post your set up here and I'm sure someone will be able to help.
John Schuster is offline   Reply With Quote
Old 07-12-2013, 06:08 AM   #370
Racermac73's Avatar
How much split between front and rear tire size are you guys running ... been told 7mm but my car seems better with 6mm
Old 07-12-2013, 06:51 AM   #371
Lil Paul's Avatar
Default Tire Split
The car will run better with a 7-8mm split, nice overdrive. Good starting point is 66-74, then go from there depending on tire wear and length of main/heats.
Lil Paul is offline   Reply With Quote
Old 07-12-2013, 08:16 AM   #372
Varying your split or overdrive is just another tuning aid , the 6mm split will make the car more stable coming off a corner see post 340 for a link to the Serpent overdrive calculator.
Empire Racing - Serpent - K.O. Propo Electronics - Tornado Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 07-12-2013, 10:03 AM   #373
I followed everything on the default setting, but the car is still understeering. Tyre: 67/74mm height:7/8mm
That's the only thing I changed.
Old 07-12-2013, 11:38 AM   #374
Make sure your suspension is not binding.
Here are some changes from the default set up that you can try.
Assuming your running Matrix 32 shore fronts and 35 rears.
If you run at a technical track with tight turns or 180's shorten your wheel base both front and rear lower A-arms.
With 4 or 5mm caster spacers in front of upper front A-arm.
250 mm front track width.
Lower front shock position.
Move front upper A-arm insert to the inside position.
Increase front axial offset by moving the shims.
Mount Body more to the front.
Make sure your bumper is not bottoming out on the pavement. If so increase ride height.
Make front and or rear shock dampening and or spring changes.
You should not need to do this but you could use an optional softer front bar or hard rear bar.
Also make sure you are using a strong enough steering servo and enough duel rate.
Hope some of these ideas help.
Old 07-17-2013, 09:50 AM   #375
cho~ke's Avatar
Default Nationals
R&D = rebuild & destroy
Jimmy Cho
cho~ke is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 01:09 PM
SEO by vBSEO 3.5.0
