Like Tree12Likes
Old 06-16-2013, 01:25 PM   #346
Hy guys,
I do have a problem with the brake.
As even if i "brake" manually, pressing the brake link forward with the hand, i can easily move the tires.
I build everything correct together, i degreased brake disc and brake pads, nothing is binding.
The brake pin even pushes the brake disc easily, but it seems, as the springs are too strong or long, i dont know.
Did anybody had the same problem? Maybe you have some tipps for me?
Maybe you can show me a picture of your brake pin guide, in which direction its, mounted with the brakr pin, or give me numbers how bigs the difference from brake disc to the other brake disc,
Thanks a lot in advance.
WFHB is offline   Reply With Quote
Old 06-16-2013, 02:54 PM   #347
Racermac73's Avatar
Double check and make sure you don't have brake mount upside down on the bulkhead
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 06-16-2013, 03:35 PM   #348
dougday's Avatar
Originally Posted by WFHB View Post
Hy guys,
The colette that you screw into must go through the hole in both pads. It is probably locked against the inner pad instead of going through.
Or the brake arm maybe too far forward. Slip it off the spline and reset angled more to the rear.
dougday is offline   Reply With Quote
Old 06-17-2013, 01:11 AM   #349
M7H
M7H's Avatar
Hy guys,
If you are really sure nothing is binding and everything is working properly, just drive the car, and you will see the brakes will become stronger once worn in a little bit, also don't forget you really don't need a huge amount of breaking, to lock up the rear tyres.
Serpent
M7H is offline   Reply With Quote
Old 06-18-2013, 12:51 AM   #350
Thanks a lot for your first comments.
Tomorrow im going to doublecheck everything again.
Some guy in the 747 thread talked about cutting one column of the springs of, to reduce the space from brake pad to brake pad, is that also a reasonable solution if nothing helps out?
Old 06-18-2013, 04:26 AM   #351
lil-bump's Avatar
Trader Rating: 83 (100%+)
Yes , I had to do the same thing to my 747. The spring was slightly too long when fully compress so I cut one ring of the spring.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-18-2013, 05:43 AM   #352
Racermac73's Avatar
Do the aerodicks help at all and are they worth getting
Old 06-18-2013, 10:47 AM   #353
2CARTEAM's Avatar
Are you refering to the carbon wheels disk that attach to the front and rear uprights? If so yes they are worth the investment. The enhance stabilty and help to increase steering. You may want to consider a few other options that will help in the tuning of the car.
1. Alum Servo saver
2. Soft and hard anti roll bars for front and rear.
Hope this helps.
RC Target, Capricorn, Tesla, Ko Propo, Ulti tires.
2CARTEAM is offline   Reply With Quote
Old 06-23-2013, 04:25 PM   #354
Racermac73's Avatar
What are you guys doing to keep front bumper from dragging the track
Old 06-24-2013, 11:25 AM   #355
Racermac73's Avatar
Or could someone post a picture showing what they've done to keep it from dragging... thanks
Old 06-24-2013, 12:22 PM   #356
Under what conditions is the "dragging " occurring - all the time?? - need more ride height - under hard braking?? - possibly firmer front springs. the board can be a useful tool but you need to give the crew a little better desription of the issue.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 06-24-2013, 12:25 PM   #357
Racermac73's Avatar
All the time, it hangs down 3-4mm below chassis plate
Old 06-24-2013, 12:36 PM   #358
Soethings radically wrong - kit bumper mounts on top of the chassis plate and the body mount goes on top (ends up flush with the bottom of the chassis plate and surrounds the nose) using the outer two holes - take a look at the car images on the website and see if by accident the wrong bumper was in your kit.
Old 06-24-2013, 06:54 PM   #359
nitrodude's Avatar
Post a pic. Is the bumper bent from hitting board?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 06-25-2013, 12:22 PM   #360
2CARTEAM's Avatar
Check your assembly. We've never had this problem with either our 966 or 977. Both cars share the front bumper. We may have gotten a slight rub but only when were down to 60mm on the front tires and even then it will usually bottom out on the chassis. Let us know what you find
out.
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
