Like Tree7Likes
Old 06-03-2013, 11:02 AM   #316
Julius's Avatar
Actually 6 vipers in the final!
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 06-06-2013, 05:46 AM   #317
Racermac73's Avatar
What do you guys start at for tire size
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 06-07-2013, 01:22 PM   #318
dougday's Avatar
For practice, I start with Rear 74 and front 67. For qualifying I start with 72/65.5 and do 2 rounds with that. Sweet spot is about 71/64.5
dougday is offline   Reply With Quote
Old 06-07-2013, 01:52 PM   #319
I start 75 rear 68 front. Never ran under 72 rear 65 front. This will depend on ride height, track and tire compound. Start high then you have more tire to play with. After 3 mils you will have to clean them up, unless you have the perfect set up.
Theo49306 is offline   Reply With Quote
Old 06-08-2013, 07:27 PM   #320
What about for qualify and final? Front:67mm/Rear:74mm?
Capricorn LAB C801/OS ENGINES/FUTABA/FUTABA
victor1997621 is offline   Reply With Quote
Old 06-09-2013, 05:34 AM   #321
Paulie Bee's Avatar
BTW, the 977 requires an 8mm starting split F/R for the new internal drive ratio.
5+3warm-up=8 min Qualis ok for 66F/74R or as low as 64F/72R starting size.
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 06-09-2013, 06:45 AM   #322
What about tire angle? At what angle does one recommend to cut the rear tires?
the numbers above are for outside diameter?
Thx!
mhavlena is offline   Reply With Quote
Old 06-09-2013, 06:50 AM   #323
Lil Paul's Avatar
Default Finals
For finals/mains it really depends alot on length of final. It is important to measure your tire wear during quals so you have a good idea of what to start final at. You want to be in that sweet spot by the middle of final when race hits a nice rhythm, but want to make sure enough rubber is there to carry you to end. For that reason I usually true 1mm over on the side that has more turns (right handers vs left handers)
Lil Paul is offline   Reply With Quote
Old 06-11-2013, 01:32 PM   #324
2CARTEAM's Avatar
Hey Paulie
The 8mm split are you measuring from the inside or outside of the rear tire?
RC Target, Capricorn, Tesla, Ko Propo, Ulti tires.
2CARTEAM is offline   Reply With Quote
Old 06-11-2013, 01:48 PM   #325
wingracer's Avatar
Trader Rating: 23 (100%+)
I usually put the rears all the way into the jaws (which have a bit of a recess on the inside) So I'm kinda measuring the middle.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-11-2013, 04:49 PM   #326
Paulie Bee's Avatar
Originally Posted by 2CARTEAM View Post
Hey Paulie
Hey guys:
Always the outside rear or fronts. The insides to middle will wear as they wish based on chassis camber and track so we can't count on the inner measurement. For example, you may start with a trued tire with 1 degree of cut camber and by the time your done running it, the tire has 3 degrees of camber cut into the foam. Right? The more valid variable is the outer part of the tire.
I'll take a #3 and a Pepsi
Thank You...
PT RC Racing Oils
Old 06-11-2013, 10:17 PM   #327
Hey guys:
Hey Paulie,
When we true the tyre, we will also have to true the side of tyre , to make it
obtuse. When I set up my car, the camber is front:2degree,rear: 2.5degree. if i use trued tyres,will the tyre changes the camber? how to true tyre in 2degree
(Which I want the chassis camber is 2degree and 2.5degree.)
Old 06-12-2013, 06:43 AM   #328
Omarf's Avatar
HI guys,just finish putting my viper together and wanna now what method you guys are using for rebound of the shocks.
Xray T4 2014,NT1 2012 spec .12 novarossi 353 mod Serpent Viper 977 team spec .21 Picco torque,Futaba,Savox,Serpent S811 2.0 Buggy .21 Picco Boost.
Omarf is offline   Reply With Quote
Old 06-12-2013, 11:37 AM   #329
Racermac73's Avatar
Why are guys cutting the holes out on the front bumper ? Is it just for weight
Old 06-12-2013, 12:49 PM   #330
lil-bump's Avatar
Trader Rating: 83 (100%+)
Better corner entry.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
