Like Tree7Likes
Old 05-20-2013, 01:51 PM   #301
anyone got any tips for the adjusting the rear roll bar, I find it hard to get too.
cheers Burty
burty is offline   Reply With Quote
Old 05-20-2013, 02:02 PM   #302
bcebwecb's Avatar
cheers Burty
For setting droop and stuff like that? I like to have the set screw facing towards the outside of the car. When I want to loosen the set screw I push the roll bar forward so I can actually get to the screw. When I want to tighten the screw I do the same thing.
Brandon Cho
_______________________________________________________________________________
Team ARC USA - Hobby Authority Distribution - TiTAN BLITZ - ActivRC
bcebwecb is offline   Reply With Quote
Old 05-20-2013, 03:54 PM   #303
cheers Burty
Not 100% sure of the issue , if it's getting to the set screws Brandon's answer above has it covered - if it's side to side balance I substituted some turnbuckles that I had kicking around that have holes drilled into them and then just made an adjusting tool from1/16th music wire.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 05-20-2013, 03:59 PM   #304
Sorry guys,should of explained myself better ,just when I'm tweaking the car , I fing it hard to adjust the length of the rod.
Cheers burty
Old 05-21-2013, 01:46 AM   #305
M7H
M7H's Avatar
You can easily reach the rods, with a hex driver from under the rear arms....
http://serpent.com/product/411063
Serpent
M7H is offline   Reply With Quote
Old 05-21-2013, 03:14 AM   #306
Julius's Avatar
Eh rear side uses tie rods. You're referring to the front...
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 05-21-2013, 03:24 AM   #307
M7H
M7H's Avatar
hahaha...
My mistake, going for coffee now.....
Serpent
Old 05-21-2013, 04:48 AM   #308
The item between the tank and the pipe, is that a cooling chamber? What´s the brand?
http://www.rctech.net/forum/attachme...r-img_1520.jpg
Valerio is offline   Reply With Quote
Old 05-21-2013, 05:43 AM   #309
Looks like an older Mugen item - probably has a minor cooling effect but at the time it was thought of as providing more volume to the pressure loop attempting to remove the spikes in pressure - current direction seems to be cooling also and the Nova one is in very common use.
Old 05-21-2013, 07:57 PM   #310
Paulie Bee's Avatar
Originally Posted by Lil Paul View Post
Paulie, one last question.....at least for this week...
Did you first build your car to the default setup? I dont need any of your secret tweaks, but were there any settings you recommend I use that may differ from default setting. Better yet, what feel does the default setup give the car. I like alot of steering, and I characterize FBF as technical/tight with medium traction. Therefore, I usually pull setup sheets off serpent site that are for tracks with similar qualities. Just trying to catch up as quick as possible. Getting a late start to this season. New girlfriend, daughter graduating HS, shucks, its a wonder I am even able to think about racing...
Thanks again for all you help!!!!
Matter of fact: Anyone that can shed some light I definitely welcome all advice, drove Mugen for the last 7 years, and the last snake I raced was the 950, so I havent had a reptile as a pet in a good while...
Lil Paul:
Sorry for the late reply.
Build the car box-stock. The 977 VIPER is far from the 950. After you use the car and decide on your body and tires for the season, then we'll talk about what you feel on the car and what your missing. Keep those two variables constant (Body and Tires) as your coming back to racing and start with a good balanced car. Other people's set-ups are for other people. The box-set-up was developed for us average racers to start from. Learning by research, testing, trial and error and then more testing will make you understand what to do to your car no matter what track you place your car on.
Paulie
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 05-29-2013, 06:52 AM   #311
BardSmith's Avatar
Trader Rating: 61 (98%+)
Smile
I just bought my new 977 - pumped! I'll be building it this weekend. This may have been answered but what suggestions, hop-ups, set-ups, etc. should I do/consider? Look to your left, I'm passing!!
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 05-29-2013, 07:14 AM   #312
Just like Paulie B advised someone up above - start with the base kit setup , it's an excellent starting point. My opinion is the first two hop-ups are the aluminum servo saver lower and the weight , of course you'll want to get the alternate bars (grab both the heavy and light) and some springs either sie of the ones in the kit (download the spring chart from the website). I'm sure you'll be pleased kit goes together very well with everything fitting almost perfect right out of the box.
Old 05-30-2013, 03:43 PM   #313
2CARTEAM's Avatar
You may also want to consider the carbon rim covers part# 903579 & 903578. Besides that Mr Davis hit the nail on the head. Enjoy your build and the car.
RC Target, Capricorn, Tesla, Ko Propo, Ulti tires.
2CARTEAM is offline   Reply With Quote
Old 05-30-2013, 04:49 PM   #314
bcebwecb's Avatar
Also consider the front flex system, depending on your driving style you may like it.
http://serpent.com/product/903576/
Brandon Cho
Old 06-02-2013, 12:16 PM   #315
dougday's Avatar
Mark Green wins ENS, Michael Salven is 3rd. 5 Viper 977 in finals
dougday is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
