Like Tree2Likes
Old 05-13-2013, 08:48 PM   #286
Paulie Bee's Avatar
Default Solution coming for rear shock-length/ droop questions
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 05-14-2013, 12:18 AM   #287
Bravo!
peppernick is offline   Reply With Quote
Old 05-14-2013, 03:08 AM   #288
The stand pipe is too short. I have made ​​one a little longer so that the pipe stays in correct position? You think so?
Valerio is offline   Reply With Quote
Old 05-15-2013, 06:48 PM   #289
Paulie Bee's Avatar
Default Pit-Caddy
I just received the new Pit-Caddy #190500
I'm impressed. Good construction, side-pockets and slots for the tools.
Really nice job.
Thank You...
PT RC Racing Oils
Old 05-15-2013, 08:11 PM   #290
Lil Paul's Avatar
Default Thks
Originally Posted by Paulie Bee View Post
Cut off 2mm on the three stock screws and check it. It might need a little more than 2mm.
I think 2mm should work. Gonna play it safe and cut more if need be. What servos are you running Paulie? I just picked up a couple of Savox. Excited to see how they perform.
Lil Paul is offline   Reply With Quote
Old 05-16-2013, 02:27 AM   #291
Paulie Bee's Avatar
I've been happily running all KO Propo radio and servos now for many years.
Savox should be fine.
You will need to place the small rectangular servo-spacers (kit) behind the servo "ears". I believe there are 3-4 different width spacers. For steering for example, try and see which spacer for savox will line the servo horn perfectly so that the horn is about 1mm-1.5mm away from the tank when in the back position. Same for the throttle, the horn with the ball on it should line-up and allow the linkage to snap-on perfectly at 90 degrees. Just play with the different spacers and you'll get it.
Have fun!
Thank You...
PT RC Racing Oils
Old 05-16-2013, 06:24 AM   #292
Lil Paul's Avatar
Default Initial Setup
Paulie, one last question.....at least for this week...
Did you first build your car to the default setup? I dont need any of your secret tweaks, but were there any settings you recommend I use that may differ from default setting. Better yet, what feel does the default setup give the car. I like alot of steering, and I characterize FBF as technical/tight with medium traction. Therefore, I usually pull setup sheets off serpent site that are for tracks with similar qualities. Just trying to catch up as quick as possible. Getting a late start to this season. New girlfriend, daughter graduating HS, shucks, its a wonder I am even able to think about racing...
Thanks again for all you help!!!!
Matter of fact: Anyone that can shed some light I definitely welcome all advice, drove Mugen for the last 7 years, and the last snake I raced was the 950, so I havent had a reptile as a pet in a good while...
Old 05-16-2013, 06:43 PM   #293
My settings are as per original factory instructions, except I went back to a narrower front end (following the assembly addendum of widening the front axle) for more steering. My measurement from the chassis to the outer edge of the steering pivot is 90mm instead of 91mm.
I found the centre 38g weight ballast extremely useful in changing the handling chracteristics of the car. If I want more steering, pushing the weight all the way back made all the difference. Depending on where you mount it, the added weight also made the car more balanced. Highly recommended tuning option.
Old 05-17-2013, 01:26 AM   #294
M7H
M7H's Avatar
1 other very nice tuning option, are the inserts in the front steering blocks.
Setting the blocks "trailing", so with the inserts pointing to the rear, will even give you more on-power steering out of a corner.
If you drive a low grip track, and you are suffering with on-power oversteer out of a corner, setting the steering blocks "leading" will help a lot to settle the car down.
(check my set-up on serpent.com from the race in Genk, Belgium)
With my Viper, I even moved the body (PF P909 Pro light) more to the rear, so instead of 20mm in front of the middle of the bumper, I'm having it at 16mm....
Serpent
M7H is offline   Reply With Quote
Old 05-17-2013, 04:33 AM   #295
I have a little question, if I want the car has more steering so I just push the 38g brass to the back? In my 747, I push the 25g brass to front If I want more steering,so did I make a mistake?
Capricorn LAB C801/OS ENGINES/FUTABA/FUTABA
victor1997621 is offline   Reply With Quote
Old 05-17-2013, 05:36 AM   #296
lil-bump's Avatar
Trader Rating: 82 (100%+)
The 747 and 977 follow the same theory. Move the weight to the rear adds more steering.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 05-17-2013, 10:54 PM   #297
What body shell do most Viper 977 owners have?
Old 05-18-2013, 05:47 AM   #298
Lil Paul's Avatar
Thks!!! Thats exactly what I was looking for. Hope to finish it today. Everyone seems to be happy with 909 body, so I may go and grab a couple of those. I picked up 128 body already.
Old 05-19-2013, 10:53 PM   #299
blanks596's Avatar
Trader Rating: 14 (100%+)
most here in LA are using 909, but I'm using an R15; haven't tried the 909 yet
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 05-20-2013, 12:53 PM   #300
LOW ET's Avatar
Trader Rating: 94 (100%+)
i picked up a couple 128's for mine.
LOW ET is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
