Like Tree2Likes
Old 03-29-2013, 09:49 AM   #196
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by ghn-sp View Post
Hi WAD, so wich tuning options do you suggest ?
GHN
I didn't get a chance to test them yet, since I only got the car and raced it right away. I will post when I test them to see what you need.
Walter Diaz
wad is offline   Reply With Quote
Old 03-29-2013, 10:53 AM   #197
Thanks....I will be waiting your opinion.
GHN
ghn-sp is offline   Reply With Quote
Old 03-31-2013, 12:24 PM   #198
LOW ET's Avatar
Trader Rating: 94 (100%+)
does this car use the same springs from the 966, 23mm in front and 27mm in rear?
which receiver pack fits?
LOW ET is offline   Reply With Quote
Old 03-31-2013, 04:59 PM   #199
Yes, same springs & battery
desotoracing is offline   Reply With Quote
Old 03-31-2013, 07:26 PM   #200
Just finished assembling my car over the weekend, looks ace!
Space is very limited as one side you have the fuel tank and the other side the long side belt. I found 5 cell NiMH pack easier to mount as it doesn't have the balancing wire that gets in the way of either the fuel tank or the belt.
Also, to remove the battery pack from the car to charge it is a pain as the side belt and exhaust pipe need to be removed to access the battery pack. With a NiMH pack, at least I can charge the battery with it still bolted onto the car. With a LiFe or LiPo pack, I found it very difficult to get to the balancing wire with the battery on the car.
I would like to hear how some of you mount your battery packs. Took me the better half of yesterday to get the wirings out of the way.
peppernick is offline   Reply With Quote
Old 03-31-2013, 09:47 PM   #201
2CARTEAM's Avatar
We were able to use a lipo in the car and we charge it in the car. We used a 6" extension that we attached to the battery and routed it around the tank and through the slots in the radio tray. When we've had to remove the battery I simply remove the two screws, drop and tilt the battery out between the chassis and the belt. Since the lipo in thin enough there is plenty of room to do so. I hope this helps. Enjoy the ride it's great.
Originally Posted by peppernick View Post
Just finished assembling my car over the weekend, looks ace! :nod
RC Target, Capricorn, Tesla, Ko Propo, Ulti tires.
2CARTEAM is offline   Reply With Quote
Old 04-01-2013, 11:26 AM   #202
Julius's Avatar
Balancing of lipo receiver packs is hardly ever nescessary. So you can charge in the car via the lead close to the rx box.
Balancing can then be done during the charge when you rebuild the car at home...
That's how I do it.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-01-2013, 06:29 PM   #203
That's how I do it.
We do the same. The Xceed 105001 packs works perfect.
Old 04-02-2013, 01:57 AM   #204
M7H
M7H's Avatar
Originally Posted by nitrodude View Post
The stinger is on the wrong end on those Hipex pipes
No, it looks awesome!
Just something to get used to, no big deal.
Serpent
M7H is offline   Reply With Quote
Old 04-03-2013, 10:36 PM   #205
Hi there M7H.When I screw down the fuel tank all the way,this fuel tank still can move slightly... Isn't okay??
Capricorn LAB C801/OS ENGINES/FUTABA/FUTABA
victor1997621 is offline   Reply With Quote
Old 04-04-2013, 02:16 AM   #206
M7H
M7H's Avatar
thats ok, the tank needs to sit "loose". otherwise the fuel in it will start to form foam, because of vibrations from the engine.
Serpent
Old 04-04-2013, 10:05 AM   #207
Rick Vessell's Avatar
The big brown truck stopped at my house yesterday. Time to let the wrenches fly.
Rick Vessell is offline   Reply With Quote
Old 04-05-2013, 09:42 PM   #208
Did anyone have a problem with the servo saver binding when you put the upper graphite piece on it? Step 35. Thanks!!
Nitrojeff is offline   Reply With Quote
Old 04-06-2013, 07:14 AM   #209
Paulie Bee's Avatar
Thumbs up No problems with the servo saver binding
Hello Jeff. No problems at all.
In fact, the servo saver was super free and spun like a top with the carbon piece screwed down. Check that you: 1)screw the lower spring holder 902135 at least .5-.75mm screwed up past the lower thread so that the alum is not below the thread, 2) inserted the 6x10mm bearings completely, and 3) that the upper black plastic bushing 903569 is inserted completely as well. There should be no issues at all.
Paulie
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 04-06-2013, 01:09 PM   #210
Just finally got to drive the new car and It is really impressive. Out of the box with the box stock setup and on the first full power run I am with in 2 tenths of my old car. The kit went together with ease no problems what so ever. serpent has built a really amazing car, to anyone on the fence about this you will not be disappointed.
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
2013 FLORIDA WINTERNATS DATES jrice Nitro On-Road 288 10-02-2013 12:09 PM
