Ofna GPX4 RTR????
#31
Originally posted by RC Driver Gary
Tried that...and when I shimmed it out from the shoes so it didn't drag I wasn't getting enough clutch engadgement and I couldn't get it out of 1st gear.
#33
Well, at this point if i were you I'd just replace any and all suspect parts in the centex assembly. Maybe the bell is bent? the bearing? or the thrust bearing? did you check if you put the thrust bearing in the correct order?
#34
#36
Originally posted by buboy28
JEFFREY: are the OFNA guy that placed 4th at the recent ROAR santionced race
The pro driver Jeffrey Lin is not on R/C Tech.
#37
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
Ok, I know this is confusing but there are 2 Jeffrey Lin there. What adds to the confusion is that we are both from Taiwan originally and now both in LA AND races at Revelation. At last month's Airtronic Championship, the OFNA and Skyline sponsored pro driver Jeffrey placed 4th in the expert/pro class. I, on the other hand, not sponsored and do this for fun, placed 4th in the Amateur/Sportsman class.
Oh yeah the kawahara shock stay you gave to me for my FW05RR is working really great!thnx bro
Are u goin to race in VEGAS this weekend?
Ken li and peter chuu is goin I've heard.
#38
Originally posted by kyoshoBOY
Hey jeff wassup! Did you race yesterday sunday clubrace at rev?how'd you do?
#39
Hey wassup! Thanks again for marshling for me at the Airtronics race. I am in Asia at the moment and won't return until next week after the Vegas race so I will miss that. Bummer!
No prob. About marshling anytime bro!
I'm not goin to vegas either,didn't get a vacation earlyanyways their still a lot f races to come
#40
CLUTCH PROBLEMS! Yes!! I had clutch problems with my GPX4 that wasted 2 race weekends! After finally getting the carb set to something like a decent operating condition - no thanks to the manual, I could not get any drive, even when the motor was screaming. Double checked the end float on the clutch bell and it was within the spec. Tried backing off the spring tension, but still no bite. Finally took the motor out and looked inside the clutch.
I found a washer between the rear of the clutch bell and the rest of the clutch 0- none shown in manual! So I removed it and placed it with the other shims on the thrust bearing side to maintain the right end-float. It still doesn't hook up as well as any similar style clutch I have used before, but at least it moves forward. Any clutch tips anyone?
For an RTR car, this has sure been a challenge. Not sure what a newbie would make of it!
I am now ready to make my first lap of a track this weekend, a full 6 weeks after I bought the car! Yes! I bought an RTR so that I could get out on the track quicker and have less work!
Now I know what RTR really means:
Ready to Rip apart, Repair, Re-align, Rebuild and then RACE!
#41
#42
There probably is a PRO version of the car, but I am not sure that buying an upgraded version of a car that you are having problems with is the best solution. I would be more interested in some ideas about improving the existing car and improving the way that Ofna manufactures, assembles and markets these things!
I finally got 5 laps in qualifying and the car handled like a dream, but the clutch was still not hooked up correctly and it began to slip so badly that my race day was over at that point. Since I run the races I have no time to rebuild stuff on race day. I will strip the clutch again and see if I can find the problem.
I would love to hear if anyone else has had this same issue or any other problems with the GPX4 and especially what they did to solve them.
#43
Regarding your clutch Racegypt. One thing you might want to try is to remove the clutch and shave out a little plastic from the 3 holes on the clutch. just enough to smoothen it out though, after make sure that the clutch is moving up and down smoothly on the post. Your clutch may not be engaging properly because there is some sort of binding between the three pins and the clutch. thats what i did on my GPX4. I hope this helps
Also don't forget to wipe off the excess grease inside of the two speed or else your car will not shift properly. The grease comes from the bearing.
#44
Thanks, that sounds like good advice. I suspect that either the clutch shoe is binding or the weights are not moving freely. I will strip it all and start again.
