IDM EVO 4 .12 con rod dimensions
Hi
I'm just looking for the dimensions of the IDM EVO 4 .12 con rod if any knows that'd be great thanks.
[quote=JamesHealey;11392725]Bet the guys @ www.dhmodelsport.co.uk can help you with that![/quo
where do you want to use it??
That's great I'll check them now,thanks a lot.I'm trying to run it in a mega zx12 dsii that I want to get running to use for a while,I'm pretty sure that's based on an evo2 but I could get an evo4 con rod easier if it's the same size,thanks.
it can not used in the evo 2-3.the only that can do is put a evo 4 crank or take your crank and go in a millshop to grid down the evo 2-3 crank pin so you can fit the evo 4 rod.the lower pin is thinner in the evo 4.
Alright I think I'll just leave it and get a new engine then.Thanks a lot for your help.
