Mugen MTX-4
#8311
I got mine yesterday!
Busy with the build, should hopefully be ready for the weekend.
Kit looks great so far
#8312
#8313
yeah it better be ready for a maiden run
get that first run under the belt and then belt it.
That is a sweet kit
What you gonna power her with ??? JP ???
Have fun with the build
That is a sweet kit
#8314
Proe, I am working as fast as i can, to try and get everything ready for tomorrow, hopefully i can start breaking in the Nova, but i have to still paint the body and prepare the engine for run in.
Bloody clients wont leave me alone!!! I have shifted all appointments to monday but im still on stand-by if anything should go wrong, so im holding thumbs.
Razzor, Thanks, it was either this or the G4S but there is no parts support at the track for the G4S
Kit is looking really great though, its going to be powered by a Novarossi Plus 12-3C with a Nova 2630 pipe with a medium JP manifold, cant wait to see what that combo is gonna do its been sitting in its packaging for over a month already waiting for the MTX4
#8315
The 2-speed housing is also diffrent. Now it fits better an hasnīt so much gap like before.
#8317
Originally Posted by JetMD
I always have problems getting the forward screw in because all of my wires are there. I guess you could trim it a little to make it easier to get on.
#8318
Originally Posted by TomB
update on the striping gears issue for mtx4 drivers
i had a lightweight steel 2 speed shaft installed since the car was built, (apporx 1 year ago) well it showed some signs of wear near the one way bearing and the 2 speed housing area, although nothing that would "seem" to cause striping.
well i have been stripping gears every 5 minutes lately, and have tryed everything, and i mean everything (replaced all components from back end, and also cut down the carby ball end so it is smaller) well the last thing i changed was the 2 speed shaft, and since then i did not strip a gear....yet.
so if you are stripping gears it may well be a worn out 2 speed shaft, put in a new one, as the wobble you get from a worn shaft on the 2 speed housing may be enough to cause stripping.
honestly i think the issue is that mugen designed the pinion and spurs wrong. the teeth on the pinnion do not contact enough of the spur (ie only 1 full tooth makes contact, and another 2 just grab half a tooth)
If they kept the old pinions the final drive would be to low.
#8319
I get a zip tie and I tie them up and try to get them up as high as possible and the good thing with the zip tie is if they do drag the only thing that will would be the zip tie. Also be sure to have the zip tie end facing down for further space and safety of the wires. Did this on my r40 too.
#8320
Just got kawahara pro (4t) 4mm chassis ..... hehehe
BTW, I'm making myself difficult : MTX4 or G4S for FEMCA 2007 (27, 28, 29 May 2007 ).
G4S, definetely is nicer car to drive, but reliability for 3 days event is rather questionable. And I hate G4S radio tray...... I'm worried to fall into changing crystal situation...... It's Gawdammn troublesome for re-arrange the cables & ballons. And my receiver battery in that car is not fresh.
MTX4, definetely is more reliable car for 3 days event. But my MTX4 still has mysterious understeering on mid cornering...... and it feels not as nice than G4S when driving underpressure. I don't have to worry about MTX4's battery receiver.
#8322
I understand your pain. I used to like G4 so much but the radio tray on G4S is really a pain. I broke the extansion wire when trying to work on the radio tray
for longer event I probably will go with MTX (yes I am bias ) at least if you have trouble with battery you can ask MTX, RRR, and NT1 dudes if they have extra to lend you.
the issue with MTX is chronic gear stripping syndrome, if you are immuned like me, that is not an issue
#8323
As far as driving under pressure goes, the Active Hobby Atenza SR that I recently tried makes the 4 really stable.
#8325
As A1 said, have you got the new uprights and rear camber link?
Also have you tried the option 1.3mm front shock pistons ?
BTW i like your new Kawahara bling
