Mugen MTX-4
#6046
Originally Posted by Nitro$junkie
i would like to eat my words just snaped a front cv today, shitty 3racing crap dont use them didnt evan crash or hit any thing
#6047
Originally Posted by AMGRacer
This has probably been covered before, but is it fairly usual for the MTX4 to eject dogbones when you give it a good whack to the front end? I ejected a bone and lost an outdrive today. Shame too cause the car was fast.
Also how long are most of you getting out of your bearings? One of my front small stub axle bearings is already toast. It was the one I gave a whack to, perhaps it sustained some damage. Funny thing is I never killed a R40 bearing in 2 1/2 years...........
Change to front CVD's... and be smart, get the Mugen ones, not the 3Racing, ask for NitroJunkie what happened with their last pair...
Narrow a little your car. If you're spitting dogbones, maybe you're going too far with the width of the car. The first thing I've changed on my MTX3/MTX4 was the front dogbones for CVD's.
#6048
Cheers and catch up with you soon. Are you heading over to the worlds to watch the final next weekend as i am coming down to volunteer.
Daniel
#6049
Get the Mugen always.
#6050
Originally Posted by rmdhawaii
Looks like they are doing well. Here are the most recent practice results:
http://www.200mmifmarworlds.com/Default.aspx?tabid=329
#6051
Originally Posted by asw7576
Why some people ( I see quite a lot of people ) get 0 laps, 0.0000 Best Time. Are those people prefer to skip the practice session ? Is it okay to skip the practice session?
#6052
They are not using their transponder.
#6054
hey guys, just sorting my 2 speed out now, if i left my car off the ground and rev it max, would it change into 2nd gear??
just wondering coz im using this way to see if its changing properly, atm its not changing at all
thanks mat
thanks mat
#6055
thanks mat
thanks mat
#6056
Hello every one,
i am almost done with my car. I am now doing the linkage for the throttle and brake. Any tips? Also how tight should my brack be adjusted?
Thanks,
John
Thanks,
John
#6057
Originally Posted by jhigga15
Hello every one,
Thanks,
John
Thanks,
John
Set transmitter and receiver ON
Start making necessary adjustments : (1) Throttle first, neutral and maximum point with your EPA, end point adjustment. At neutral position make sure the carb is at almost close position. Adjust spring tension so the carb shut at neutral. (2) Brake second, neutral and maximum brake, with EPA. Watch carefully as you brake the throttle's spring compress even more.
Take off the servo horn if necessary to align the throttle / brake linkages ( make both linkages parallel, straight and flat as possible ).
#6058
I'm experianceing something strange. What I am having is a push issue. I couldn't seem to get rid of the push this past weekend. Running Ft Myers, I tried running from 1mm to 3.5mm of split and I still had a push. After 10min in the main, the car "woke" up and started turning. I was all over with the setup and did everything I could think of.
Here is what I discovered. When the tires wear to the same size, the car is great, and after that the tires wore the same. This is the first time I have had this happen. Usually running a 1.5mm split, everything wears the same.
My next time racing, I am going to run the same size tires to start and see if this makes a difference, but I wanted to see if anybody else is experiancing the same thing?
#6059
MTX-4 parts for sale NEW
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE%3AIT&rd=1
click on other items by this seller to see everything
#6060
