Mugen MTX-4
Old 09-02-2006, 01:08 AM
  #5971
Trader Rating: 28 (100%+)
Originally Posted by Adim_X
I dont think you are correct, that would totally throw off the pitch of the gears.
They are the same size. They "cheat" on the pitch in order to make the gears the same size. This allows you to change the spurs without having to adjust pinions as well.
Scott Fisher is offline
Old 09-02-2006, 01:24 AM
  #5972
rmdhawaii's Avatar
The FAQ section of the the MTX-4 Knowledge Base is now online.
rmdhawaii is offline
Old 09-02-2006, 02:00 AM
  #5973
chookgb's Avatar
Trader Rating: 29 (100%+)
how long have they been cheating with the pitch and which gears have the greatest variance from the correct pitch??
chookgb is offline
Old 09-02-2006, 03:13 AM
  #5974
Fixed my problem with the gear mesh
since its raining today i cant break in my new engine
is the best break in method heat cycle?? and can i have a gd link on how to do it please
since its a new engine the flywheel does not spin all the way round since the piston is very tight. how do i start it then??? just put in fuel and let it lub itself or...??
thanks in advnace
mat
bigboss is offline
Old 09-02-2006, 03:18 AM
  #5975
kidDynomite's Avatar
Rainer, that is wicked. Thanks for all the hard work. That saves us a lot of diggin-around time. Now we can just send the confused or newbies to the FAQ. Heck, I'll be sending myself there.
kidDynomite is offline
Old 09-02-2006, 03:40 AM
  #5976
rmdhawaii's Avatar
Thanks Tommy!
Just a few more things to work on and all the sections will be populated. Then I have to go through everything again, tidy up a bit and put the site into maintenance mode - which is the easiest part. Too bad I have to race this weekend. JK! JK!
Old 09-02-2006, 05:17 AM
  #5977
Trader Rating: 17 (100%+)
Thanks Tommy!
Rainer,
Sould have pics and PDF file ready for you today or tomorrow. Send to your regular email?
BTW, the site looks awesome, thanks for the hard work.
Jamie Corrado is offline
Old 09-02-2006, 09:58 AM
  #5978
rmdhawaii's Avatar
Originally Posted by Jamie Corrado
Rainer,
Thanks Jamie and thanks again for the interview! You can send the pics and setup file to my regular email.
Old 09-02-2006, 02:08 PM
  #5979
AMGRacer's Avatar
My rear belt stripped all its teeth last night quite abruptly. I was using the stock urethane belt with the adjuster cam in the stock loose position. Have many other people had issues with the rear belt stripping? Any ideas what causes it?
AMGRacer is offline
Old 09-02-2006, 03:43 PM
  #5980
itchy b's Avatar
i had the same thing happen to my car 2 weeks ago, only i had 3mm of belt unbroken.
the the rest got jamed between the diff and the rear part between the bulkheads which took out all the teeth on the diff and only left what the 3mm rear belt was riding on
as it was a new belt that i'd fitted i was a little annoyed
oh well, a new belt and new diff casing and it'll be good as new
will you be in bris next week??
cheers
joe
itchy b is offline
Old 09-02-2006, 03:46 PM
  #5981
wallyedmonds's Avatar
i did this with both the urethane and rubber belt in my case it was just old,with the motors haven so much power today i find you got to change them more often.i did this with the mtx3 and 2 cars too so its not the car.and dont run the belts tight,they will strip faster.
wallyedmonds is offline
Old 09-02-2006, 04:25 PM
  #5982
AMGRacer's Avatar
cheers
joe
Yep I will be around. Raced Logan last night, Wynnum next weekend and watching the worlds finals following weekend. Should be fun!
AMGRacer is offline
Old 09-02-2006, 05:24 PM
  #5983
itchy b's Avatar
cool,
look for these bodies if your there for practice
Attached Thumbnails Mugen MTX-4-att5-small-.jpg   Mugen MTX-4-aus1-small-.jpg   Mugen MTX-4-pb1-small-.jpg
itchy b is offline
Old 09-02-2006, 07:11 PM
  #5984
Default 2 speed
Newb questions here.
How big of a gap should the two speed halves have?
When adjusting the two speed do i have to turn both 2.6x12 screws? At what increments?
And what increments are you adjustiing the clutch spring (engine). And how are you doing it without the mugen adjustment tools.
thanks in advance.
rai
rai13 is offline
Old 09-02-2006, 11:51 PM
  #5985
itchy b's Avatar
has anyone had a problem with the diff leaking from the outdrives?
my diff has this problem and the casing is near new
the out drive do have 1mm movement in and out.
should i put extra shim or 2 to eliminate this movement between the inernal gear and the Oring?
cheers
joe
itchy b is offline
