Mugen MTX-4
#5656
Originally Posted by Heartsword
Could somebody let me know the use of the hole indicated?
THX very much!
THX very much!
#5657
Long track setup
Please can someone hit me off with long track setup with lots of corners
4 my mtx4
4 my mtx4
#5658
4 my mtx4
4 my mtx4
#5659
hello, is there a newer ver. of MTX4 coming out? as people said, the "newer" ver. has only a minor (one or two mods) changes on the car. IS that true? and what is/are the mods. on the car?
#5660
4 my mtx4
4 my mtx4
Sow, man, you crack me up. But aren't you in the wrong hood?
#5662
#5663
Originally Posted by Sow&Steady
Forget the 4, use the car on the left ... stock setup with 56 2nd gear spur and the long steering servo lever. You're set then!
Btw, madbeats, here is the setup for Fantastic 4 ( on the right ) :
Spur Gears : 52/58
Pinions : 18/24
The rest follow the original setup manual. When possible use 1.3 piston all around.
#5664
on the right and i see you drive a VW is that your car if it is nice car i drive VW too
#5665
Originally Posted by Bing
Yes, the newer ver. come with new belt tension plate and they put something in fuel tank to measure fuel capacity.
#5666
whats wrong with the belt tension plate for them to change it,or is the change so you dont have to take it off every time you change your motor and the gas tank why
#5667
#5669
Originally Posted by itchy b
if it ain't broke why fix it Miu'gen Miu'gen
they were the only improvements nessesary for the car, its already an awsome car
#5670
U Da Man
Originally Posted by asw7576
Hahaha.... I like your visit
Spur Gears : 52/58
Pinions : 18/24
Spur Gears : 52/58
Pinions : 18/24
