Mugen MTX-4
#5401
Originally Posted by jeff whiting
So what is the general performance thoughts about the Mugen 4mm chassis. I have bought one but there is nothing wrong with my stock one at this point. Looks to me like having a little more weight down low might help...not to mention being stiffer. Of course stiffer is not always better.
JEFF
JEFF
#5402
JEFF
JEFF
#5403
Originally Posted by wallyedmonds
the 4mm chassis has better cornering speed but theres diff ones to get, the kanack 4mm chassis is stiffer than the mugen,i have both,and a thicker chassis is more stable at high speed,a thiner chassis is lighter yes but it flexes and makes the car unperdictable.
#5404
Originally Posted by speedy100
i read the japan artice about testing the mugen 4mm, they commented 3mm chassis have better cornering but 4mm gives you a bit stable in the long straight, the kawahara 1 piece engine mount really help to stiffen the 3mm chassis. The kanack 4mm is a nice piece but majority of people would prefer mugen 4mm as it has the offset area for low CG, which the hobby shop told me when I was there in Japan.
i had the knack 4mm chassis. it is definately a super strong chassis
#5405
Originally Posted by TomB
i actually went back to 3mm chassis. i found the 4mm too twitchy and it did not steer the way i liked it to on some high speed s sections on my track.
#5406
I believe the chassis looks like a banana now...
#5407
the mugen chassis is 4mm but you do the drop the same as the stock one,a 3racing or kanack you do it diff,mugen 5mm drop in the rear but on the kanack its 6mm to be the same cuz the mugen is milled out on the top kanack is not and you can run the one peace motor mount like on the stock, i do run both chassis
#5408
#5409
#5410
Originally Posted by Snowy
If TomB says the Knack chassis is strong but twitchy, beleive me, he would know. He hit just about everything on & off the track when he was using it, including a poor turn marshall. Not in the leg but on the thigh!!!
TomB: increase the height of rear suspension upper link and add more front & rear camber by another 1 degree ?
#5412
can someone help me with a pipe/manifold kit that would be best for an mtx4 with an os tz engine? looking for part numbers so that i have everything i need, the last pipe i bought only had the pipe, no other connecting hardware and i'm not sure i'm getting maximum performance out of it because i had to mix and match parts. thanks for the tech help on this thread!
racer-oZ
racer-oZ
#5413
does anyone noe when the mtx-4 prospec will be out?
Mike
Mike
#5414
Mike
Mike
Originally Posted by stefan
August 22, 2006, 12:34 p.m.,pacific time
#5415
i live in toronto ontario ( IN CANADA) ....do you tihnk it would be over the winter time or just at the end of the season???
thanks
Mike
thanks
Mike
